![]() | Home > Puma (Tdci) > Power Steering has gone missing? |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 736 ![]() ![]() ![]() |
Is your auxiliary drive belt tight and not slipping?
Yannis Member Since: 02 Feb 2015 Location: Oxfordshire / Milan Posts: 408 ![]() ![]() ![]() |
Checked that as well. Thought it may have been slipping when it got wet but no.
At least one of them isn't. ![]() Seriously though, there aren't many parts to the system, If the belt is in good condition and not slipping and there isn't fluid leaking out of somewhere then it's either going to need a new steering box or Pump. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20592 ![]() ![]() |
Sounds a bit like the pump, as that'd mask any signs of failiure hence full fluid level no leaks etc. Play Stupid Games, Win Stupid Prizes.
Big Brother is Watching. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
Swine&Small Member Since: 20 Mar 2017 Location: Norfolk Posts: 1223 ![]() ![]() |
what is the mileage of the vehicle/ 1983 Series 3 Pick up in Marine Blue
1967 Morris Traveller 1966 Morris Convertible 2012 VW T5 Camper Quod Abundat Non Obstat. |
Around 16,000
Any LR Warranty? Play Stupid Games, Win Stupid Prizes.
Yes, going to call the local dealers tomorrow and see who can fit me in soonest.
Hi. Well that is just ridiculous for a fault to appear at that low mileage, i think a fast trip with your warranty in hand is called
for ![]() S & S 1983 Series 3 Pick up in Marine Blue 1967 Morris Traveller 1966 Morris Convertible 2012 VW T5 Camper Quod Abundat Non Obstat. |
if you phone LR Assist they might replace it on site for you.
So I just got in to go to the dealer and the power steering seems to have returned?
Maybe an airlock? But how would that be possible? Unless some funny angle when off road caused it to suck in some air from the reservoir. Thoughts..? |
I'm no expert but maybe it wasn't fully bled. Play Stupid Games, Win Stupid Prizes.
So.....
It had fixed it self, then it failed again, now it seems to be working??? |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1809 ![]() ![]() ![]() |
is there a pressure relief valve in the pump?
If so it could be sticking open, see if it will repeat the fault by holding it on full lock? good luck Keith |
