Home > Maintenance & Modifications > Rear speakers in a double cab
Page 2 of 2 <12
Glynparry25
How come you are routing it over the top? Would it not be easier to just take it down from the stereo to the carpet and then along the floor? that was my plan once I get around to fitting a sub but have a million other things to do first.
Glyn Dog Sheep
Post #61672 1st Mar 2011 3:32pm
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
Glynparry25 wrote:
How come you are routing it over the top? Would it not be easier to just take it down from the stereo to the carpet and then along the floor? that was my plan once I get around to fitting a sub but have a million other things to do first.Glyn Dog Sheep
Mr. Green Because I don't have a carpet ! I would see the wires coming from underneath the passenger or driver's seat ! Whistle ....and going to the back ! My DC is a basic spec one ( E version ? ) And since I have to fit the roof console for the CB I was thinking on routing everything through the roof lining !! I just would like to know the best way to remove it, as well as what parts of the dash do I have to remove, if any ... Don't want to remove anything I don have to ... Very Happy Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #61681 1st Mar 2011 4:09pm
Glynparry25
Good reason Smile.
There is a tool to remove them (it is like a lever bar with a special fork end) but from experience half of them will break whilst removing so it would be a good idea to get a few in just in case.
You shouldn't have to remove any of the dash, just reach in from where you can.... then just take the A-pillar trim off to lead it up to the roof.
Glyn Dog Sheep
Post #61683 1st Mar 2011 4:18pm
lrmaniac
Glyn Dog Sheep
Something like a pincer plier would do the job? I'l try to find something ...
and go get some spare plastic rivets ... just in case ... ! Mr. Green ...and I'll try to find my way through the dash ... ! I'll post pics when I fit it !
Thanks! Regards
Joao
'08 BMW F800GS
'69 SIIA 109 ZA CKD
Post #61687 1st Mar 2011 4:28pm
Grenadier
Re: Rear speakers in a double cab
TC wrote:
Morning all,
Done a lot of searching on this topic but haven't come up with what I need.
What options are there for mounting rear speakers in a Double Cab? I have replaced the fronts and am about to fit a small powered sub. I don't want over blown sound, just full sound.....
I read that Alex had mounted 6x9's in enclosures behind the rear seats. If anyone has pictures of this type of install and views on sound quality it would be appreciated.
Cheers Bow down
TC
TC, what did you eventually do with your DC? I'm going to have to try something as well on my DC. Also, can't decide if I want a flat Sub below the rear seats or a rearward facing one attached to my cubby. What did you do? Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #548697 14th Jul 2016 11:06am
TC
I ended up with a small self contained unit under the back seat. It was pretty useless though to be honest; if you are serious about doing it then your money would be better spent on sound deadening the entire cab and once done, fit a decent set of cross overs and a small amp up front.
You could build an enclosure for a sub below the rear bench but it would be very small / low capacity. I rapidly arrived at the conclusion that without forking out an arm and a leg there was no solving the problem...As said though, it isn't really about the power you can squeeze out of any speaker or device you put in the cab, it's about what happens to the sound once you start generating it - you have to deal with the fact that the acoustics are no better than a tin can.
You can get a budget version of dynamat on fleebay at a reasonable price, much better to strip the cab down completely and get wallpapering!
Post #548698 14th Jul 2016 11:15am
Wow, a thread from the dead!
In my DC in the end I didn't bother with rear speakers, I upgraded the front speakers and fitted a sub underneath the cubby, raising the cubby on a home-made riser unit thingy to accomodate the sub.
The sound is pretty good, and the cubby is a much more comfortable height for resting the elbow whilst driving.
Post #548699 14th Jul 2016 11:16am
Roy5695
I made my own custom sub enclosure to fit behind the rear seats and in the very near future will be making some fiber glass pods to fit in the corners to house some 4 or maybe even 5 inch speakers.
Post #548702 14th Jul 2016 11:36am
Grenadier
Thank you both. Going for a full SilentCoat and Mat of the interior, very keen on really tackling the rattles and tinny sound throughout. I will have at least Focals upfront, but ideally throughout. Even thought about popping the LR Tweeters into the headlining in each rear corner.
10cm to replace stock, with suitable tweeters.
http://www.feuvert.fr/enceintes-haut-parle...52314.html
Then this mixed Amp/subwoofer which looks slim enough to possibly slip under the rear seats.
http://www.feuvert.fr/ampli-caisson-subwoo...91682.html
Finally a pair of 13cms behind the rear seats,
http://www.feuvert.fr/enceintes-haut-parle...52319.html Monsieur Le Grenadier
Post #548703 14th Jul 2016 11:37am
Page 2 of 2 <12
