Home > Puma (Tdci) > botched up stone chip colour
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Am I doing something wrong?
My 90 (2011) is stornoway grey. I have used a little bit of primer, and i have two types of paint. A genuine parts touch up stick, and a touch up pen with felt nib.
regardless of which one i use the paint is really dark.. even after 5 minutes of shaking in warm weather. Whats going on? it sticks out like a sore thumb Sad
 1953 80"
1987 mini city e
2011 90"
Post #420219 30th Apr 2015 4:30pm
Mjibex
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Loire Blue
Are you sure it's not Orkney Grey?
Post #420237 30th Apr 2015 6:10pm
Happyoldgit
Primer affecting colour coat? Does it come with a clear lacquer, if so have you tried using it? Steve.
http://forums.lr4x4.com
Post #420238 30th Apr 2015 6:11pm
Mjibex
To clarify, your Defender looks Orkney & the touch up looks Stornoway.
Post #420239 30th Apr 2015 6:13pm
andydef90
United Kingdom 2014 Defender 90 Puma 2.2 HT Corris Grey
just to be check your vin plate colour code touch up should be a closer match not often as same as process is of batch colours never the same even if same mix
Post #420395 1st May 2015 10:38am
MR_JAMES
Thank for your advice! My paint code on the chassis plate is 907 which is Stornoway grey. I have two paints now from different suppliers and they are both to dark and really stick out.. Not sure what to do? 1953 80"
1987 mini city e
2011 90"
Post #420420 1st May 2015 1:02pm
K9F
Get a stonechip company to do it, there's loads about. It's not expensive and they'll get a perfect match. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #420423 1st May 2015 1:09pm
Rickydodah
If it's any help Stornaway has a white primer Thumbs Up I started with nothing and still have most of it left!
Post #420435 1st May 2015 2:27pm
I've had little success with paint sticks too.
Airbrush by a professional would be better in my opinion or live with the battle scars.
Everything normally tells a story even down to a stonechip.
Post #420471 1st May 2015 5:30pm
arran jones
Hello All,
My paintwork just under my windscreen has got a few stone chips that have turned to little rust spots!
Is there any thing that I could spray onto the paintwork(Blue) to stop it and prevent anymore stone chips,
I have dinitroled inside through the door hinges but obviously I can't spray that on paintwork,
Any comments would be appreciated Thumbs Up
Arran
Post #616096 11th Apr 2017 5:19pm
You can get clear protection film from somone like 3M.
Thumbs Up Play Stupid Games, Win Stupid Prizes.
Big Brother is Watching.
Post #616097 11th Apr 2017 5:24pm
Sammyboy
United Kingdom 2012 Defender 110 Puma 2.2 USW Sumatra Black
Disco3
Had a Stornoway Grey D3 and had exactly the same problem. Never did resolve it!!!
Post #616105 11th Apr 2017 6:26pm
arran jones
OK thanks custom90 Thumbs Up
Post #616119 11th Apr 2017 7:18pm
arran jones
Is it sticky on 1 side, so I just stick it on or do I have to use glue sort of stuff!!?
Post #616124 11th Apr 2017 7:26pm
X4SKP
Puzzling this colour match problem... Shocked
I had to touch up a few stone chips with Stornoway Grey recently, and painted the heads of a few SS door bolts. I was really please with the colour match, the Lacquer didn't change the colour it just added the gloss finish.
For Stornoway make sure it's VEP 501730 LEL
 SKIP
Post #616149 11th Apr 2017 8:20pm
