Home > Puma (Tdci) > botched up stone chip colour |
Mjibex Member Since: 21 Mar 2013 Location: Reading Posts: 284 |
Are you sure it's not Orkney Grey?
30th Apr 2015 6:10pm |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
Primer affecting colour coat? Does it come with a clear lacquer, if so have you tried using it? Steve.
30th Apr 2015 6:11pm |
To clarify, your Defender looks Orkney & the touch up looks Stornoway.
30th Apr 2015 6:13pm |
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 |
just to be check your vin plate colour code touch up should be a closer match not often as same as process is of batch colours never the same even if same mix
1st May 2015 10:38am |
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 249 |
Thank for your advice! My paint code on the chassis plate is 907 which is Stornoway grey. I have two paints now from different suppliers and they are both to dark and really stick out.. Not sure what to do? 1953 80"
1987 mini city e 2011 90" |
1st May 2015 1:02pm |
Get a stonechip company to do it, there's loads about. It's not expensive and they'll get a perfect match. If you go through life with your head in the sand....all people will see is an ar5e!!
1st May 2015 1:09pm |
Rickydodah Member Since: 14 Jul 2014 Location: East Sussex Posts: 1091 |
If it's any help Stornaway has a white primer I started with nothing and still have most of it left!
1st May 2015 2:27pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20593 |
I've had little success with paint sticks too.
Airbrush by a professional would be better in my opinion or live with the battle scars. Everything normally tells a story even down to a stonechip. |
1st May 2015 5:30pm |
arran jones Member Since: 21 Nov 2016 Location: south west Posts: 728 |
Hello All,
My paintwork just under my windscreen has got a few stone chips that have turned to little rust spots! Is there any thing that I could spray onto the paintwork(Blue) to stop it and prevent anymore stone chips, I have dinitroled inside through the door hinges but obviously I can't spray that on paintwork, Any comments would be appreciated Arran |
11th Apr 2017 5:19pm |
You can get clear protection film from somone like 3M.
Play Stupid Games, Win Stupid Prizes. Big Brother is Watching. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
11th Apr 2017 5:24pm |
Sammyboy Member Since: 28 Feb 2017 Location: Hampshire Posts: 121 |
Had a Stornoway Grey D3 and had exactly the same problem. Never did resolve it!!!
11th Apr 2017 6:26pm |
OK thanks custom90
11th Apr 2017 7:18pm |
Is it sticky on 1 side, so I just stick it on or do I have to use glue sort of stuff!!?
11th Apr 2017 7:26pm |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
Puzzling this colour match problem...
I had to touch up a few stone chips with Stornoway Grey recently, and painted the heads of a few SS door bolts. I was really please with the colour match, the Lacquer didn't change the colour it just added the gloss finish. For Stornoway make sure it's VEP 501730 LEL Click image to enlarge Click image to enlarge SKIP https://www.defender2.net/forum/topic83242.html |
11th Apr 2017 8:20pm |
