Home > Technical > How do I silence my alarm?
Williamraff
United Kingdom 2006 Defender 110 Td5 CSW Alveston Red
Hi folks, as above my alarm on my 2006 110 CSW goes off at the most inappropriate times - usually 3.00 am in the morning Shocked
Is there any way I can retain immobiliser function but silence the alarm until I can get time to check all the connections / sensors?
Many thanks, Will.
Post #614805 5th Apr 2017 11:39pm
grafty99
Be wary, thieves somtimes set off peoples alarm until they disable it, then when they trigger the alarm and it doesn't sound they steal the vehicle. I would have it checked out immediately for fault rather than disabling the sounder Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #614808 5th Apr 2017 11:51pm
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
I've had this occasionally with mine, particularly if it's been very windy and/or I've left a window open a tiny bit for ventilation, or more so if I leave the dogs in the car while I nip into a shop or whatever.
I now have mine set on the 10AS alarm module so that locking with the key fob sets the alarm fully as normal, but locking it with the key in the drivers door locks all the doors and sets the immobiliser and the alarm via the door switches but does not activate the internal motion sensor.
I'm not sure if this is the default setting anyway but if not it's easy enough to set with a suitable diagnostics kit. (I use a NanoCom Evo.)
Prior to this, I used to pull the volumetric sensor out and unplug it when it became troublesome, so that's always another option.
Post #614854 6th Apr 2017 9:27am
gcc130
As above, I lock my 130 manually with the key when I leave the dog in the cab or at nights on campsites, but I wouldn't want to do this overnight on my drive.
Alarm and immobiliser work as normal but not set off by movement or insects in the cab.
Post #614860 6th Apr 2017 10:19am
Laurie
Used to happen with my TD5 Defender. I sprayed the door switches with WD40 which cured it completely and permanently. (Except for the odd moth or fly that gets trapped inside.)
Post #614861 6th Apr 2017 10:29am
Williamraff
Thanks for the replies, much appreciated. The vehicle is on axle stands on the drive at the moment and the wheels are locked away so I don't think it is a twocker trying to be devious ?
The courtesy lights are dodgy at the moment so I will try them first and if all else fails there is the key locking option. They would also have to get past my Audi A6 first so that should stall them until I and / or the dog get my hands on them Twisted Evil .
Cheers, Will.
Post #615058 7th Apr 2017 2:03am
zsd-puma
You've only got 6 switches to check (including the bonnet), it's probably going to take just as long to check the switches as it would to disable the alarm.
Post #615079 7th Apr 2017 7:44am
chopcat
Wales 2000 Defender 90 Td5 CSW Java Black
Can you nit just unplug the alarm sounder with the battery backup? That's what I am going to try if mine does not stop misbihaving.
I hae a bit of advice from Steve at JFrench who mentioned that the loom to the sounder runs along the nearside wing and often gets rubbed so that you can get occasional shorts setting the alarm off. Might be worth a look
TC
Post #615093 7th Apr 2017 8:36am
Remember that the alarm activates the vehicle horns as well as the BBUS. Removing the BBUS won't stop the noise.
Post #615096 7th Apr 2017 9:04am
Williamraff
Cheers, Will.
I hear you - and they need looking at anyway Thumbs Up .
Post #615249 7th Apr 2017 9:16pm
Williamraff
Message received and understood Smile .
Post #615250 7th Apr 2017 9:17pm
Williamraff
Sorry - can you explain BBUS?
Thanks, Will.
Post #615251 7th Apr 2017 9:19pm
BBUS = battery back-up sounder, the thing that makes the racket if the thieves cut the battery cables to disable your alarm.
Post #615257 7th Apr 2017 9:33pm
Williamraff
Got you Thumbs Up
It's sounding more and more as if I am better off tracing the cause rather than addressing the symptom Idea
Many thanks, Will.
Post #615703 9th Apr 2017 11:35pm
