Home > Maintenance & Modifications > MAF & MAP Torque for fixings
Can anyone provide these figures for me?
I'm not entirely sure if it applies to the MAF but I know the MAP sensor has a torque setting oir its fixing.
I can't seem to find these details in the WSM, but my guess is it is there but buried amongst many pages.
It's for an early Puma 2.4.
Thank-you.
Thumbs Up Play Stupid Games, Win Stupid Prizes.
Big Brother is Watching.
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #614866 6th Apr 2017 10:41am
Had a closer look, found the MAP fixings which are 3 Nm.
MAF is on there, but no mention of torque.
I assume that means to say common sense fitting, I.e. Not over tightened but enough. Play Stupid Games, Win Stupid Prizes.
Post #614882 6th Apr 2017 12:00pm
Not critical, use common sense.
Few people would have a small enough torque wrench anyway.
Post #614899 6th Apr 2017 12:51pm
Seems that way. Thumbs Up Play Stupid Games, Win Stupid Prizes.
Post #614902 6th Apr 2017 1:11pm
Well I got both removed today, the MAF was a little dirty but not too bad. (Still needed cleaning!)
The MAPT however, is and was absolutely junked.
I think it needs replacing to be honest!
I've cleaned both now, so hopefully all should be good for now but I think I will replace the MAP shortly.
Probably best to remove and clean the manifold also if I replace the MAP.
Post #615127 7th Apr 2017 11:21am
Is your EGR disabled? I think you need a catch can on your breather!
Post #615152 7th Apr 2017 2:21pm
It is indeed blanked.
On google image search it seems quite common for them to be contaminated this much.
Many even worse.
Mind you, I have never cleaned it until now so could well be original from new!
I never knew much about it in the past.
Once again the WSM was invaluable.
They both cleaned up nicely, dried perfectly clean placed on a piece of paper for a few hours and I've since refitted.
Tested, all is good idle seems smoother and the drive is better.
It may have been these two that was aiding the erratic idle I've had as it has since gone.
The over rev / rev hang has also gone but I suspect that is the bridged clutch switch mod I made the other day.
All in all, much much better and back to normal.
The MAF was much cleaner than the MAP but still needed cleaning.
Very pleased.
Post #615156 7th Apr 2017 2:41pm
A few photos:
MAF Sensor and printed P/N's:
MAP inc electrical connector:
Post #615160 7th Apr 2017 2:53pm
Leviathan
Any chance of an idiots guide on what to do with what please Steve? With pictures of were these things are Confused
It looks like something I should be involved with on mine. Thumbs Up
Post #615163 7th Apr 2017 3:01pm
Will see what I can do later. Thumbs Up
They are easily accessible to get at, I've used Holts Brake cleaner.
It'll loosen deposits and blow them away with pressure and completely dry as its solvent.
It's best though imo to leave them out to dry in a clean place for a few hours to be safe.
They also must be disconnected from the electrical system plugs first.
Don't touch the element or electrical plates and wires, simply use the cleaners pressure to blow away the rubbish.
I did this twice, first time to loosen the deposits and give it a chance to work and a second blow though ten mins later.
With the MAF I blew it though in the flow direction as marked on it, as airflow direction would be in use.
This is the location of the MAF (not my photo, used as guide reference only).
As you can see, the airflow directional arrow must be observed when refitting.
This is located on top of the air box housing to the left front of the engine bay.
The electrical connector red tab needs be pulled up, then you can press below it as it will remove.
The red tab is like a safety mech, so it doesn't accidentally come loose or get pressed.
There are then the two T20 Torx screws to remove, refitting is the revers of removal.
Tightening wise on these, just use common sense so tightened enough but not too much.
The MAP:
This is located to the RHS of the engine block on the manifold, easily seen as this photo shows.
It has one fixing, subject to a Torque tightening figure of 3Nm.
Cleaning much the same as the MAF.
The electrical connector is more basic, remove in much the same way as an Econoseal connector.
Just push tab down and release.
WSM page ref MAP:
The following applies to both MAF & MAP sensor:
I cleaned everything I could before removing anything with a clean lint free terry towl cloth to avoid contamination.
Once removed I blanked the holes with electrical tape.
On the MAPT / MAP the WSM suggests replacing the 'O' ring seal, personally I see no merits in doing this if it looks in good condition and is not perished.
Mine looked good, so reused.
If it gets to a state that bad imo the whole thing may as well be replaced anyway.
I may do this at a later date...
I cannot remember the size of the fixing for the MAP.
However, you should be able to use a smaller Torque wrench with reducing adaptor on it.
This is what I did with no issue at all.
Hope this helps, some may do it slightly different but this I should what I have done.
The Clutch Switch thing is a different thing all together, I may put that up in another's thread.
This also seems to work well in my opinion.
Quite happy now! Thumbs Up
Hope that helps. Play Stupid Games, Win Stupid Prizes.
Post #615168 7th Apr 2017 3:59pm
Apologies for the long posts here.
Howver, just out of curiosity and as I have the pics of the P/N's on both the MAF and MAP it allows me the chance to do something further investigation.
(I haven't looked up the MAF yet).
There is a Bosch P/N on there on the MAP which I can tell from the Logo, and also a Ford P/N as well.
Looking up these P/N's on eBay, they correspond to the same item for only around £40 ish!
As mine has 'Made in Germany' on it, I'm pretty sure it's made by Bosch but corresponds to FOMCO's P/N too.
I'd be inclined to follow the Bosch P/N myself personally.
Now, I haven't looked all that's deeply into this yet but will do tonight or over the next few days.
I wonder what LR's list price will be for the same part? Twisted Evil Whistle
Time to find out I think for both. Wink
***EDIT*** PM'd Dan @ Duckworth Parts for a quote of price and Genuine P/N's for both sensors.
This will be interesting.... Play Stupid Games, Win Stupid Prizes.
Post #615175 7th Apr 2017 4:17pm
Leviathan
Thats great thank you.
I have some carb cleaner, do you think that will be ok to use?
Post #615199 7th Apr 2017 5:49pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Steve, MAP sensor from Ford are under £30 i can't remember from the top of my head as I didn't pay too much attention to the invoice, I had a pair for a Transit this week, MAF are slightly more but under £50.
Dread to think what JLR charge for the same part?? Wink 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #615203 7th Apr 2017 6:35pm
Leviathan - It should be. But if you wanted to get what I had it's only about £8 or so on eBay or where ever.
You can get stuff just for MAF cleaning but it's much the same.
Ian - IIRC last time I checked the MAF was around £120 from JLR. Shocked
Will wait to hear from Dan, I'm guessing ball park that figure for each! Shocked
Been on a longer trip tonight, power fully restored! Goes like stink again.
All my issues I did have were related to the clutch switch, MAF and MAP.
Power lag gone, slight shunt of changing gear gone.
Minor hesitation and rev hang, slight over rev occasionally on gear changes gone.
Fuel consumption had dropped off slightly.
And no extra ECM revs applied when engaging low range 1st either.
Gear changes are more crisp, and no shunt from ECM revs applied immediately after gears engaged.
Although I've cleaned mine with good results for the price I'll change for new soon as they are getting on for ten years old now.
But cleaning has definitely done the trick, and something I will do again.
LR don't do it with servicing at all. Rolling Eyes
All this has cost me is a few quid for some clutch switch connectors and a can of brake cleaner.
Mr. Green Play Stupid Games, Win Stupid Prizes.
Post #615210 7th Apr 2017 7:14pm
ian series 1
Nice one Thumbs Up
£120..... Now that's a serious mark up!
I must say I've never asked the price from LR, that's probably why Shocked 80" 80" 86" 88" 90"
Post #615214 7th Apr 2017 7:27pm
