Home > Off Topic > Gaffer tape residue
lambert.the.farmer
England 1998 Defender 90 300 Tdi PU Rutland Red
Gaffer tape residue
Hi all. About 6 years ago some gaffer tape was applied to various bits of plastic trim in the Jimny to supposedly protect it, yeah right, ok. Now the fabric has died leaving the glue welded on. What is going to shift it? Oh and wd40 doesn't touch it.
Any ideas? Rhubarb and custard let fly with their secret weapon.
Post #614382 4th Apr 2017 6:29am
rockster57
United Kingdom 2011 Defender 110 Puma 2.4 CSW Zermatt Silver
Lambert, have you tried brake cleaner fluid? It's not just an excellent product for cleaning brake pads and surfaces but also grubby and greasy parts and a very effective solvent for the general stickiness you refer to. If you decide to buy some, I recommend you avoid the aerosol variety. In my experience it's not as effective and has a poor shelf life. I buy in bulk (5 litre) and use a pump dispenser.
Post #614387 4th Apr 2017 6:52am
lambert.the.farmer
I haven't but I think I might have a tin on the stores. Will give it a go. Rhubarb and custard let fly with their secret weapon.
Post #614392 4th Apr 2017 7:00am
rockster57
forgive me if you're familiar with the product but I don't mean hydraulic brake fluid - not at all the same thing as brake cleaner fluid. The hydraulic fluid will not just remove the adhesive residue but will strip off any paint surfaces too Embarassed
Post #614394 4th Apr 2017 7:07am
leeds
If the brake cleaner idea does not work, just look on flesbay for adhesive remover.
Brendan
Post #614395 4th Apr 2017 7:08am
Fat Cog
Hair dryer it, get it really hot & sticky then use turps, meths, anything alcohol based...hair dryer is the key to success! Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains
Post #614399 4th Apr 2017 7:20am
rockster57
Another good use for the hair dryer whilst you have it out - pop on a yellow fluorescent vest and point your hair dryer at the inconsiderate oncoming traffic speeding down your street - and amuse yourself at the drivers reaction Laughing
Post #614403 4th Apr 2017 7:32am
agentmulder
Kuwait
There's a product called Goof-Off around here, which is pretty much rebranded Acetone. Not sure if you want that around your paint work and plastics though.
Next step down in terms of attack is Desolve-It which is 'citrus based', and yeah, not sure what that means but it certainly has a bit more punch than isopropyl alcohol and methylated spirits.
But yes, agree to above, heat works wonders! Solved the bowel problem, working on the consonants...
Post #614405 4th Apr 2017 7:32am
Balvaig
I use "sticky stuff remover". Not an April fool. Get it on eBay or Amazon. Doesn't damage most plastics and removes non hardened glue residues etc.
Post #614412 4th Apr 2017 7:48am
lambert.the.farmer
Fortunately it is on internal trim so no painted surfaces, will have a look at one or two of the heating with alcohol or other solvents. Thank you all. Rhubarb and custard let fly with their secret weapon.
Post #614426 4th Apr 2017 8:49am
A product called TexSolve is what you need.
https://www.amazon.com/CleanTex-TexSolve-C...B0084G234S
A wonderful product but it may not be easy to find in the UK. IIRC I used to get it from RS or similar.
Post #614428 4th Apr 2017 8:53am
X4SKP
Hello lambert
Electrolube LRM Label Remover... sounds innocent enough, but this stuff will soften and remove most stubborn adhesives used on labels / tapes etc...using too strong a 'solvent' runs a risk of 'melting' the top surface of many of the typical plastics used in car interiors...
(some are thermoset Thumbs Up but many are thermoplastic Shocked and are vulnerable)
+1 for TexSolve
Good Luck SKIP
Post #614429 4th Apr 2017 9:00am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Deleted 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #614432 4th Apr 2017 9:05am
Martin
Site Admin
Also a fan of "Sticky Stuff Remover"  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #614446 4th Apr 2017 11:09am
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
You can buy a rubber disc which goes in end of drill take it of in a second 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #614499 4th Apr 2017 4:15pm
