Home > Off Topic > Gaffer tape residue |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 |
Autoglym Tar remover works well for most adhesive residues. https://www.autoglym.com/intensive-tar-remover
4th Apr 2017 8:57pm |
Rup90 Member Since: 23 Apr 2016 Location: Sussex Posts: 32 |
Agree with above - Autoglym intensive tar remover is highly rated or if you need something stronger try paint thinners (be careful with it though).
4th Apr 2017 9:05pm |
apt100 Member Since: 05 Mar 2015 Location: Derbyshire Posts: 1547 |
https://www.amazon.co.uk/Ambersil-31629-La...el+remover
Another "citrus" label remover that works well and is easy to obtain. |
4th Apr 2017 9:28pm |
lambert.the.farmer Member Since: 11 Apr 2012 Location: harrogate Posts: 2006 |
Ok thanks for all the options. So far wd40 nothing. Carplan brake cleaner nothing. Heating it as much as I dare and a scouring pad in hot soap water, best so far for the actual dirt but marginal on the residue. I'm in town later so will have a look at getting some of the other things mentioned. Thanks. Rhubarb and custard let fly with their secret weapon.
5th Apr 2017 4:44am |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
Isopropyl
5th Apr 2017 6:41am |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1763 |
All this talk of solvents in the cab it would now be suitable to throw a match in and then go back to the best small lorry in the world. Job done.
All meant in jest Lambert. Go to your local pvc window suppliers and get a bottle of solvent - it works. If you do go down the route of first suggestion then there is a lovely looking truck cab 300 tdi on carandclassic.co.uk. Local to you as well. |
5th Apr 2017 12:06pm |
As an aesthetic thing a 90 pickup one of the most agreeable things ever to look at. But I don't need to own one to look at it. Rhubarb and custard let fly with their secret weapon.
5th Apr 2017 6:25pm |
