Home > Td5 > Erm - Help! Clutch gone I think
130dreamer
Looking for some help from the wise collective.
As it is the school holidays decided to spend a couple of weeks camping in the south of France.
All going well until gear selection becomes very notchy. I think the clutch has gone.
Does anybody know of any reliable garages between Lyon and Beziers?
Having spoken to some locals the chances of getting parts may be the challenge so happy to get them sent from the UK.
Should I also get the DMF sent as well? How do I know if the DMF needs changing?
Symptoms are:
With engine off I can select all gears so gear box is OK.
With engine running and stationary cannot select gears without force.
Can start engine with box in first and clutch out, cluth seems to engage smoothly.
Can go up through the box using clutch reasonably but back down is very difficult.
I am assuming it is the clutch unless any of the experts know otherwise?
Grateful for any help. Thanks Bow down
Andy (camping in France, in the rain, with an unhappy wife!)
Post #613945 2nd Apr 2017 7:56am
alwoodley72
England 2008 Defender 130 Puma 2.4 HCPU Alaska White
Check obvious things like clutch fluid first, how does the pedal feel?
Cheers. Alex 98 300 tdi 90 project
94 Range Rover vogue 4.2 lse
79 911 sc
08 130 double cab utility
Post #613957 2nd Apr 2017 8:52am
dorsetsmith
stc 500100 master and slave ftc 5202 cylinder check for leaks and also colour of the dot 4 fluid ifs black seal are failing
Post #613961 2nd Apr 2017 9:24am
Riverboy
2014 Defender 90 Puma 2.2 SW Corris Grey
I take it you are coming down the A7? There's a JLR Concessionaire at Valence that are very good. http://www.carbury-automobiles-valence.fr
Or give Pascal a ring at https://www.lignonautomobiles.com. 0475551414 They are Indy LR dealers just south of Valence and are very helpful. They speak perfect English too.
The rest of the week is going to be sunny tell your wife Very Happy (just dont mention the Mistral)
Post #613965 2nd Apr 2017 10:07am
sharkey964
France 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
You could try these guys for your parts,they all speak English & prices are not bad either,might be quicker than post from UK.
http://www.landypoint.fr/en/
Good luck.
Marc
Post #613981 2nd Apr 2017 12:30pm
proloForêt
France 2008 Defender 90 Puma 2.4 XS CSW Java Black
I too used landypoint just last week for some pieces. Kind, quick and honest. If piece not on their website, consider a telephone call. I imagine they are good for advice for service areas in France.
Léo
Post #614006 2nd Apr 2017 1:46pm
130dreamer
Thank you all for your help, it is very much appreciated.
The clutch fluid is still at the max level and is the normal pale yellow colour of DOT4, the pedal does not feel different.
I am pretty convinced it is either the clutch or DMF.
We will be heading down the A7 so will contact carbury and lignon first thing tomorrow to see if they can help. If not I will try landypoint.
Thank you all again, thanks to you the wife is still speaking to me (which, yes is a good thing before some of you ask!)
Andy
Post #614019 2nd Apr 2017 3:05pm
dorsetsmith
When i replaced clutch last year at 100.000 mi in my 03 plate TD5, its was clutch cover plate that had most signs of ware i.e spring fingers in the centre i replaced DMF, clutch plate 3/4 way down to the rivets heads
Post #614043 2nd Apr 2017 4:43pm
