![]() | Home > Td5 > Fuel filter housing replacement |
EWS Member Since: 29 Nov 2011 Location: Bristol Posts: 156 ![]() ![]() ![]() |
Hi all.
I need to replace the housing as it fractured around the bolt holes,seems to a be common problem. I plan to use a replacement made by GORE http://goreproducts.com/products/td5-fuel-filter-housing . Am i correct in that all i have to do is transfer the connections from the old to the new, or is it advisable to replace the air bleed/non return valves, L/R or after market, any to avoid . Any trick to remove the hoses from the fittings. Edward |
Looks like you got to that just in time
![]() My build thread http://www.defender2.net/forum/topic17615.html |
