Home > Td5 > Fuel filter housing replacement
EWS
United Kingdom 2006 Defender 90 Td5 HT Alveston Red
Hi all.
I need to replace the housing as it fractured around the bolt holes,seems to a be common problem. I plan to use a replacement made by GORE http://goreproducts.com/products/td5-fuel-filter-housing .
Am i correct in that all i have to do is transfer the connections from the old to the new, or is it advisable to replace the air bleed/non return valves, L/R or after market, any to avoid . Any trick to remove the hoses from the fittings.
Edward
Post #611728 23rd Mar 2017 10:16pm
EWS
Hi All.
Replaced the filter housing today, with the GORE housing. and new internals. On removal of the hose connections the housing just fell off, as well as the corrosion around the bolt holes the ally was eaten away behind the copper washers.
Post #613614 31st Mar 2017 5:15pm
mk1collector
Looks like you got to that just in time Thumbs Up Ray
My build thread
Post #613693 31st Mar 2017 9:49pm
