Home > Td5 > Defender TD5 cruise control.....confused! |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6627 |
You need a "speedo healer" to correct the speed signal being sent from the speedo down to the ECU. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
31st Mar 2017 8:58am |
DiscoSmiley Member Since: 31 Mar 2017 Location: Alberton JHB Posts: 5 |
Thanks Martin. I will look into this. Sounds interesting. Have you done yours?
31st Mar 2017 9:26am |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 716 |
Had a similar thing with the cruise control in my 2005 Td5. A friend kindly wired in a couple of switches as per the link on the previous page and it worked perfectly. Total cost was about £10 for a few lengths of wire and some ECU connectors.
Later on the mainshaft in the gearbox collapsed and I upgraded it to a v8 5th gear ratio. After that CC would engage but knock off after 5 seconds. Last weekend I plumbed in a Speedohealer and set the reduction to 7% and all is good once again. At the same time i fitted a D2 switch onto the column and very happy with the outcome. Click image to enlarge |
31st Mar 2017 10:29am |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 |
Harry - looks neat. What have you use for the cruise on/off switch? 2005 Td5 | 90 Station Wagon | Tonga Green
31st Mar 2017 12:06pm |
steve_c3 Member Since: 30 Apr 2015 Location: Hants Posts: 173 |
That looks familiar! Same install on mine. I needed a to shave the internal metal a little to fit but seemed ok.
Click image to enlarge 2002 Defender 110 CSW TD5 |
31st Mar 2017 12:44pm |
Thanks Green Machine I had a spare Carling switch on the dash which is used as the on/off.
Steve - it may well have been your photo that promoted me to use the D2 switch! Very pleased with it so thank you I also had to trim a bit off the underside of the metal bracket on the column. Click image to enlarge |
31st Mar 2017 12:58pm |
No problem, I think I gleaned the information from another forum out there somewhere but happy to share 2002 Defender 110 CSW TD5
31st Mar 2017 1:40pm |
Which speed healers are people using with D2 transfer boxes? 1988 90 Td5 NAS soft top
2015 D90 XS SW |
31st Mar 2017 6:33pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4788 |
Healtech speedohealer from flatdog for me 2002 90 Td5 Station Wagon
31st Mar 2017 7:34pm |
Hi a Martin. There is now a defender specific speedo healer. Costs about £70. Ashcroft, flatdog, paddocks, trek overland and others sell them.
http://www.ashcroft-transmissions.co.uk/sp...n-kit.html |
Gotcha ta. Looks like a Britpart supplied item 1988 90 Td5 NAS soft top
2015 D90 XS SW |
31st Mar 2017 7:51pm |
Mine came from Ashcroft along with the transfer box. Not sure what make it is though. 2002 Defender 110 CSW TD5
31st Mar 2017 9:04pm |
That's the same as the one I used, it had a Britpart sticker on the packaging but inside is branded as Healtech. The instructions by Ashcroft say to attach it near to the transfer box plug but that would also adjust the speedo reading. I popped mine beside the ECU which Grafty99 suggested, it alters the signal just before it enters the ECU but does't affect the speedo. |
1st Apr 2017 10:10am |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2947 |
where do you wire it to
1st Apr 2017 10:28am |
