Home > Technical > Rear Brakes won't bleed? 110 300tdi
Page 2 of 2 <12
dorsetsmith
It's like the brake master cyl is only sending a little pressure down the rear circuit - when you crack the line with the pedal pushed hard down, no jet of fluid comes out.
have try work down brake line to the rear brakes crack at flexes and t piece one at a time to find out where problem is
You replaced brake line front to back not crimp or flatten pieces pipe work
Post #605195 27th Feb 2017 8:55am
jst
if you have changed the servo or master cylinder is the throw matched from the pedal position. ie the movement of the master cylinder range compared to the movement of the pedal range
If its had a new MC first (cant remember now) it may not match the current pedal movement.
i believe the fluid goes to the front first then the rear on MC piston movement. maybe you are running out of movement of the MC piston.
try adjusting (increasing) the movement by small adjustment on the threaded section that protrudes from the servo to push the MC piston.
If you adjust it too far the brakes will bind - you will know about it! Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #605323 27th Feb 2017 7:30pm
jst
did you sort this? Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #613137 29th Mar 2017 8:02pm
Page 2 of 2 <12
