![]() | Home > Technical > Rear Brakes won't bleed? 110 300tdi |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8160 ![]() ![]() ![]() |
if you have changed the servo or master cylinder is the throw matched from the pedal position. ie the movement of the master cylinder range compared to the movement of the pedal range
If its had a new MC first (cant remember now) it may not match the current pedal movement. i believe the fluid goes to the front first then the rear on MC piston movement. maybe you are running out of movement of the MC piston. try adjusting (increasing) the movement by small adjustment on the threaded section that protrudes from the servo to push the MC piston. If you adjust it too far the brakes will bind - you will know about it! Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
did you sort this? Cheers
