Home > Technical > Puma fuel gauge stopped working
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
So the fuel gauge packed up Sunday, a warning 'pinging' noise accompanied by the needle on zero and the fuel light on ... Knew i had qtr tank but stuck another £30 in just to be sure Mad
Was hoping it was a glitch, but 3 days later it's still the same ...
Is there a 'known' common problem, or is the tank going to need removing??? Guns and Landrovers .... anything else is irrelevant.
Post #609480 14th Mar 2017 8:20pm
I'm not aware of it being a common problem and would be checking the wiring for continuity and earths before dropping the tank to access the sender. Be prepared for the vehicle to implement its low fuel strategy and misfire and eventually refuse to restart if it thinks it has no fuel, by the way. Eventually it will become undrivable even with fuel in the tank if it thinks it has no fuel.
Post #609522 14th Mar 2017 10:28pm
Dave-H
Thanks for that Blackwolf Thumbs Up
Drives fine at the moment, not missing a beat [hope it stays that way until time allows repair] Crying or Very sad Guns and Landrovers .... anything else is irrelevant.
Post #609687 15th Mar 2017 7:38pm
It would be interesting if you could let us know if you do get any odd effects running like this. If the LR published information is correct, it should begin by inducing a simulated "fuel starvation" misfire, which will clear on cycling the ignition for a few times, then persist, and ultimately then inhibit engine start to prevent the system completely running out.
I don't know if it is clever enough to determine that a sudden transition from plenty of fuel to zero fuel can only be due to a fault (or, I suppose, theft) and therefore inhibit the strategy, or if it will assume that you're running out and behave as predicted.
Post #609742 15th Mar 2017 10:37pm
Dave-H
I will Thumbs Up
It's going to be a good while before it gets looked at so we'll soon know Laughing Guns and Landrovers .... anything else is irrelevant.
Post #609937 16th Mar 2017 9:01pm
Dave-H
73 miles later and It's still driving as it should Cool
Does this point towards the sender unit being fine and It's more likely a gauge/wiring issue?? Guns and Landrovers .... anything else is irrelevant.
Post #610681 19th Mar 2017 7:44pm
Have you checked the plug on the rear of the IPAC is secure? TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #610686 19th Mar 2017 7:54pm
Steve makes a good point, perhaps the issue is at the IPAC not the sender or ECU. If it is a sender fault and the ECU thinks the tank is empty, I am very surprised that it is still running.
It would be interesting to hook up a diagnostic tool and see what fuel level the ECU is reporting. If it is not empty, it points to an IPAC problem.
Post #610774 19th Mar 2017 11:10pm
Dave-H
I did unplug the cluster for a few minutes and re-connected [just in case] Also disconnected the battery for 10 minutes ... both made no difference.
I don't have any diagnostic tools good enough for that sort of info on a Defender ... Crying or Very sad
I'm with the Bro in law at the weekend, I assume I can temporarily swap the ipac for his one just to see if gauge works Blackwolf? Or are they specifically programmed to each individual vehicle's ecu?
Ta Guns and Landrovers .... anything else is irrelevant.
Post #610899 20th Mar 2017 4:42pm
dorsetsmith
with your ins cluster unplug you also can comm check wiring and fuel tank sender with multimeter
Plug C0390- pin 11 and pin 10
Plug C0114 - pin 1 / 2 is the one on top fuel tank
Post #610909 20th Mar 2017 5:17pm
Since the IPAC is an integral part of the security sytem (with the AS10 and ECM) I doubt you can just swap one over, unfortunately.
Post #610911 20th Mar 2017 5:23pm
I was going to suggest a manual check, just thought checking the plug for the IPAC would be best to try first.
The diagram makes that task all the better. Thumbs Up TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #610912 20th Mar 2017 5:24pm
Dave-H
Had a very quick look yesterday.
IPAC is fine, gauge works if plugged into bro in law's puma, his IPAC doesn't work in mine.
Assume It's not sender unit [As vehicle is still driving faultlessly] so that only leaves a wiring issue somewhere [I feckin HATE wiring issues!]
It can stay like that til I can be bothered .... Evil or Very Mad Guns and Landrovers .... anything else is irrelevant.
Post #612230 26th Mar 2017 11:10am
Could possibly be debris damage from underneath.
Hopefully it's not directly near the fuel tank. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #612231 26th Mar 2017 11:27am
dorsetsmith
With the IPAC unplugged
check wiring in stages i.e. from your IPAC to the engine bay chassis harness plug with multimeter to start with, next chassis harness plug to driver side rear wheel arch not plug I no will have to unwrap harness and find two wires green / orange 0,75 and yellow / purple 0,75. I have used pins and the multimeter con check end to end both wires if ok at this point your wiring problem from hear to tank or the sender
Using pins and the multimeter con check across the two wires see if you get reading i.e. fuel tank sender
Post #612239 26th Mar 2017 11:58am
