![]() | Home > Puma (Tdci) > HELP HELP mad electrical problem |
apt100 Member Since: 05 Mar 2015 Location: Derbyshire Posts: 1547 ![]() ![]() ![]() |
deleted now you have put the rest of the post while I was typing...
alastaid Member Since: 03 Dec 2013 Location: York Posts: 78 ![]() ![]() |
Sorry had a posting problem, hopefully you can see it now
No problem... yes can see the new post
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20711 ![]() ![]() |
Sounds as if you have electrically connnetced ignition live to permanent live.
This would give you ignition live permanently live with or without the key. As it is you need to keep the battery disconnected until you've sorted the issue or the battery will be drained. WeWillWinπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
Steve, thanks, yes I would agree that is what I thought, but I only disconnected one wire and put the same one (albeit without the piggy back on) on the same tab, cant see how I could have done it?
You should really have disconnected the battery first, I assume you didn't?
Are you 100% sure it was the same connection that was made? Is there possibility something was disturbed in the same vicinity? WeWillWinπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
OK, now sorted, Steve took your words to heart, it had to be the only answer, just couldn't see how.
So went back out, and wondered how I have done it. Then of course it fell into place. I had disconnected the piggy back cable by pulling out from behind without looking because you have a bit of spare cable. Then looked through the little hole you can see the back of the ignition barrel, with the cowls removed, and I could see a spare tab, which of course must have been the spare tab on the constant live. So when I went back out had a proper look, there was the correct tab, in an even more difficult position to get to, but hey ho, it is the solution. Plugged it up properly and all is well. Thanks Steve for your wisdom, and yes I confess I didn't disconnect the battery, but in my defense I did only nip out to go and fix the horn, funny how one thing leads another. Time for a beer, Cheers Alastair |
Your welcome.
If it's very isolated circuit then not disconnecting the battery is okay for speed of work completion and ease. The trouble is when working with various electrical bunched wiring in one place, in particular confined areas. Is that you can easily cause a short by accident, you'd have no idea until a fault develops or once on the road and something doesn't work. None the less, glad you've got it sorted. ![]() I once left the hazard switch disconnected, thought nothing of it. That was until I went out and only noticed my indicators weren't working when I got beeped at! ![]() Luckily I hadn't gone far but it was interesting using hand signals to go back down the lanes to get home. ![]() ![]() ![]() ![]() β½οΈπ’οΈβοΈπ§°πͺ |
