Home > Maintenance & Modifications > What is this accessory for ? |
Augusto Member Since: 01 Feb 2011 Location: Munich Posts: 35 |
What is this accessory for ? How does it work ? How much ? Where to order? Thanks, Augusto. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Last edited by Augusto on 24th Feb 2011 4:53pm. Edited 2 times in total |
24th Feb 2011 4:39pm |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
Stops the snow / various crap from filling up heater intake Original Member Pie n Pea Club.
110 HCPU Tipper |
24th Feb 2011 4:45pm |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 762 |
You just screw it with the existing bolts ...
It cost me 100€, 6 moths ago ... bought here in Portugal .... don't know where it came from ... It's sold by Entreq, a site sponsor ... Click image to enlarge very usefull ! Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
24th Feb 2011 5:00pm |
Thankyou.
It is quite expensive but if you suggest me I will think about it. thanks again. |
24th Feb 2011 5:05pm |
WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748 |
I bought mine from P A Blanchards ebay shop
http://cgi.ebay.co.uk/Land-Rover-Defender-...20b6c710c8 Their advert says they will post worldwide, but best to ask them first. When ordering/paying be sure to specify if its for a left or right hand drive vehicle. Mine came bare metal which Im getting sprayed when my 300tdi gets resprayed soon. |
24th Feb 2011 9:24pm |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
on about the air intake, check inside now and again as there is a rubber 'valve' at the back of intake to let rain water etc drain out, this gets glogged up and can lead to the water being drawn into the heater then onto the passenger footwell. 2.4 90 XS
25th Feb 2011 8:16am |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
On the Puma there are two rubber valves (Teet's?) on the heater intake box, unless they where removed at PDI that is.
25th Feb 2011 10:47am |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 501 |
'Snow Cowl' - as fitted to the Royal Marine's original Winterised 110s, Royal Netherlands Marine's 110s, Winter/Wading Wolf XD, as well as the Courtaulds Aerospace CAV100 (now known as NP Aerospace CAMAC CAV100), also called 'Snatch' by squaddies and the press.
Available as LH or RH fitment from Land Rover for silly-money (I have the part numbers somewhere) I got mine direct from Courtaulds Aerospace back in the early 90's I had to buy 10 to make up the minimum order value, so I ordered 5 x LH and 5 x RH, kept one of each for myself and sold the rest. Here are mine fitted to my 110 (the LH one doesn't really do anything, but it 'evens-up' the front end ) . Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
25th Feb 2011 11:28am |
2? 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
25th Feb 2011 12:12pm |
Click image to enlarge Grockle, there is one under the heater fan unit and you need to push in past the hoses to get too it (Left arrow). The other one is just under the plastic intake duct (Right arrow) towards the rear. |
25th Feb 2011 12:51pm |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
I took both mine off unless you are going wading very deep they are not needed |
25th Feb 2011 1:59pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6092 |
RRC 6817 Chamois cover intake £216 LHD RRC 6818 Chamois cover intake £216 RHD |
25th Feb 2011 2:32pm |
nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546 |
Mid this year there will be a version made of ABS plastic in LHD and RHD for a VERY reasonable price. The good side on the plastic one is that it will not punch 2 holes in your wing in case of a minor "off road accident" like the metal one does. WANTED:
SII or SIII in max 1.5k |
25th Feb 2011 2:37pm |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
So what else is coming this year then
25th Feb 2011 2:54pm |
