Home > Maintenance & Modifications > Seat box rebuild and modifications for twin batteries
Page 1 of 3 123>
Jim G
United Kingdom 1984 Defender 90 300 Tdi HT Stornoway Grey
I have just bought a Defender ( to rebuild ) and I have found that the seatbox has serious rust in the battery compartment, ... this is a bit worrying as it has 9 months MOT and this amount of rust.
Anyway, the plan is as I have to cut the bottom out anyway, I might as well make is sealed, so no more mud in there , and convert it to take two batteries and eventually my ARB compressor.
Battery was just bouncing about !
So cut the bottom off
and ended up with...
Not a lot !
 1984 300TDi hardtop Stornoway Grey
1984 200TDi hardtop..... soon to be a V8 .. but which V8 ?
1974 DAF T244 4x4 wagon converted to a motorhome
1976 Jaguar XJC with supercharged engine
Post #609666 15th Mar 2017 6:18pm
dorsetsmith
Post #609668 15th Mar 2017 6:25pm
Jim G
Thanks, ... but £77 plus VAT ?
Folded a piece of steel up myself, £8.00, and it will take two batteries now !
Post #609680 15th Mar 2017 7:15pm
dorsetsmith
I no, but you can guarantee it will fit
as you have kit to Folded sheet metal your self no problem Thumbs Up
Post #609689 15th Mar 2017 7:51pm
Jim G
True !
Works with one battery
And now with two !
Loads of welding yet to do, just put a couple of rivets in to see if it all lines up
Post #609696 15th Mar 2017 8:05pm
Why would you think a rusty seat box would affect the MOT?
Post #609740 15th Mar 2017 10:29pm
alwoodley72
England 2008 Defender 130 Puma 2.4 HCPU Alaska White
Insecure battery I would guess..
Well done Jim on a bit of British ingenuity!...
Cheers. Alex 98 300 tdi 90 project
94 Range Rover vogue 4.2 lse
79 911 sc
08 130 double cab utility
Post #609749 15th Mar 2017 11:14pm
Jim G
Yes, the battery was hanging on its wires, the mounting 'pods' had rotted out so it was completely loose 1984 300TDi hardtop Stornoway Grey
Post #609992 17th Mar 2017 8:00am
Jim G
Finished now, the usual, should take a couple of hours took a day and a half, lots of welding, but very happy with it as it will now take one huge ( long) battery or two smaller ( as came out of the Disco V8 ) batteries, also sealed now. And there is a small storage area, maybe for a locker compressor ( eventually) or tool / jump leads storage for now.
Welded strengthening on front and rear corners. Will get it galvanised, with my chassis ( if I can find one) and bulkhead.
Post #609996 17th Mar 2017 8:09am
shaggydog
What a super upgrade!
Good job looks really neat Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #610064 17th Mar 2017 1:11pm
Jim G
Thanks, should look better when galvanised,
Just ordered two new seatbox ends, lets see how easy they are to fit !
Also decided to move the seats in a bit as per my other landie.
Might move handbrake at the same time as have the discovery one here, 1984 300TDi hardtop Stornoway Grey
Post #610069 17th Mar 2017 1:26pm
Jim G
Decided to move the handbrake whilst I was at it , so using the Discovery one I made a bracket and positioned it next to the seat ( moved both seats inwards).
I also made eight 'captive nuts ' to hold the seats in.
Post #611030 20th Mar 2017 9:38pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Great job on the welding Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #611031 20th Mar 2017 9:41pm
Jim G
Back onto the seatbox mods today, fitted the modified handbrake, and mocked up where the auto shifter will go.
I mad a centre console out of scrap wood to see what it would look like....... well....
Yep.... it looks bloody awfull ! I used the Disco lid.
The cubby is only 1 inch higher than my exmoor one, but as its smaller.... it just looks awfull even with a seat
Back to the drawing board.... anyone any ideas ? 1984 300TDi hardtop Stornoway Grey
Post #611181 21st Mar 2017 6:39pm
L110CDL
What about a lower cubby box and incorporate the auto lever into the console as a whole unit ? Like in the older cars were the console did that Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #611236 21st Mar 2017 9:17pm
Page 1 of 3 123>
