Home > In Car Electronics > MUD LED Interior Lights- good bit of kit?
Page 3 of 3 <123
Keith5
United Kingdom 2012 Defender 110 Puma 2.2 USW Santorini Black
Currently awaiting delivery of: http://www.flatdoguk.com/led-interior-festoon-bulb~2516 to put in the front.
I have a mud one in the rear which is great for the space but I felt it would be a bit bright in the front and I wanted to try and maintain the standard look at the front. Keith
Post #601717 14th Feb 2017 10:13am
chris d3
England 2011 Defender 110 Puma 2.2 USW Stornoway Grey
I fitted the mud one it's great and Labcraft flush mount strip in the rear
Post #602084 15th Feb 2017 8:22pm
Gonarezhou
South Africa 2015 Defender 110 Puma 2.2 SW Alaska White
doublea wrote:
Butchers Boy wrote:
I fitted these for £2.59 FANTASTIC!! Thumbs Up
http://www.ebay.co.uk/itm/231969686365?_tr...EBIDX%3AIT
I went for these led replacement lamps. Great at first but after less than a month, individual LEDs started to fail (maybe 4 out of 10) and the remaining ones were only at half brightness. Got a replacement from the seller on eBay no problem, but after less than a week, it's going the same way.
I think you have a dud supplier or the supplier has dud stock or both! Put mine in over a year ago ..... no problems, whatsoever!
Post #602101 15th Feb 2017 8:58pm
big110
2014 Defender 110 Puma 2.2 SW Keswick Green
follow up after install
worth every penny! great mod, bright as all bloody hell!
Post #607699 7th Mar 2017 10:00pm
bogwert
Scotland 2003 Defender 90 Td5 CSW Zambezi Silver
They look pretty good.
I'm looking to upgrade the interior candles, so might be a good mod. or just go for an LED bulb! Chris
2014 Discovery 4 TDV6 HSE
2003 Defender 90 TD5 CSW
Post #609574 15th Mar 2017 9:03am
big110
You won't get nearly the effect just swapping to an LED bulb
Post #609641 15th Mar 2017 2:24pm
bogwert
True but anything would be better than the current bulb!
How easy is the MUD Stuff one to fit? Chris
Post #609642 15th Mar 2017 2:31pm
big110
Lol yes agree the current one sucks! Fitting the mud unit takes about 5 min. All the connectors are pre done so no tools needed besides screwdriver to remove old housing and screw on new! Front took me 5 min and back about 12 min because I dropped a bloody screw in the mess in the rear and took a bit to find Smile
Post #609643 15th Mar 2017 2:35pm
DSC-off
Hi I got some Ring led bulbs from Halfords, made a big difference. They do stay on though, very dim all the time, as noted elsewhere. It's never been a problem or a distraction when driving in the dark.
Worth a try, and very easy to change. It just depends on how bright you want it to be?
Post #609752 15th Mar 2017 11:37pm
dgardel
Italy
https://www.nakatanenga.de/zubehoer/innena...nder?c=203
 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #609760 16th Mar 2017 4:25am
Page 3 of 3 <123
