Home > My Defender > An Anoraks Tdi Defender 90
Page 8 of 24 <123 ... 789 ... 222324>
Liam
Netherlands
That's also an option. My consideration for the switch is that I frequently have to close a gate behind me in the dark countryside
Post #609132 13th Mar 2017 12:47pm
Procta
looking bang on there LRA, Also where did you get the paint from? yours looks like its the same colour as mine. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #609140 13th Mar 2017 1:07pm
The paint came from eBay - a seller called 'paint-my-classic. The colour of mine is Arles (sometimes called Windjammer) blue. Darren
Post #609370 14th Mar 2017 12:34pm
Procta
Spot on pal, I will get researching tonight, be handy to touch up inside too, Before I begin carpeting the full works. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #609397 14th Mar 2017 1:55pm
Profyaffle
Paintman also sells it, in aerosol and cans... I just bought some, paint code is LRC424
Post #609471 14th Mar 2017 7:58pm
Yeah, I've also bought a tin of coach enamel from Paintman, but they don't do aerosols. Darren
Post #609582 15th Mar 2017 9:21am
Profyaffle
they do now.... :thumbs:
Post #609616 15th Mar 2017 12:42pm
Sorry, failing memory. Paintman do sell aerosols but I paid far less from eBay - £16.99 as opposed to £23.34. Darren
Post #609618 15th Mar 2017 12:52pm
Procta
Very Happy Spot on lads! If you lads were closer id buy you two a drink! that's cause we have the same colour landys Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #609626 15th Mar 2017 1:12pm
Profyaffle
Cheers.. mine would be a sherry, being a lady Wink
Post #609637 15th Mar 2017 1:57pm
Today, I installed my rear worklight, although it did involve a few backward steps. I completed the control box that I showed earlier but wasn't happy with the result. It was all just too congested:
So, a bigger box and mark two was born. This time, I included an extra switch that will be used for some internal lights:
The box is mounted on the outside of the drivers side rear light cluster cover and makes use of the hole that the rear door electrics used to pass through. They'll be re-routed through a notch that I've made in the edge of the panel:
The bottom switch is the manual/off/auto control for the work light.
The middle switch controls the Hella socket on the outside of the box and its' associated indicator light.
The upper switch will eventually control some internal lighting.
Inside the panel is mounted a six way fuse board and a connector that will allow me to unplug the entire panel:
Here's the wiring diagram, less my extra switch:
And the whole thing fixed in place:
The work light was fixed centrally over the rear door, fixed through the hole previously occupied by the washer jet, which has been moved slightly to the left:
The power cable is routed through a rubber grommet just above the mounting point.
The mounting point itself is reinforced with some 6mm nylon:
It works a treat, and the auto operation at night is great:
 Darren
Post #610226 18th Mar 2017 12:07am
More progress this morning: new hub caps and pedal rubbers were ten minute jobs but the main event was installing a rear ladder:
I bought this ladder from Custom90Steve about 3 years ago and it's been gathering dust in the garage ever since. It arrived finished with cold galv, but has since been etch primed and finished with three coats of Smoothrite.
Self-adhesive neoprene has been applied to top and bottom mounting plates and the whole thing is secured with 8mm stainless nuts and bolts, that are isolated on the outside with nylon washers:
Ignore the yellow tinge. It's the remnants of glue where the previous owner had lined the roof with carpet. Darren
Post #610299 18th Mar 2017 2:04pm
Gratuitous front 3/4 shot Whistle Razz
 Darren
Post #610301 18th Mar 2017 2:09pm
L110CDL
Very nice LRA Thumbs Up Really impressed with your box and wiring, so very neat Bow down Clayton.
Keeper.
Post #610426 18th Mar 2017 9:06pm
Thanks Smile I've just ordered some lights for inside the rear so will have it all apart again soon Rolling Eyes Darren
Post #610808 20th Mar 2017 6:47am
