alastaid
Hi, could do with a bit of help diagnosing my alarm problem, it's an 09 puma, and the last two times I have used it the following has happened:
1st time - car locked in garage, unlock car, start car, no probs, then as soon as I start to reverse, alarm goes off with the horns, not siren. Go through process of turning off, locking unlocking with plipper, horn still blaring, occasionally it went off briefly on an unlock but started again. Eventually it stopped and car was normal.
2nd time - virtually identical except this time the siren went off not the horns. But car would start no probs, and drive with alarm blaring
Before the first time I had driven it the night before, it has rained a lot with some big puddles, and the second time I had washed it with karcher, so water ingress a possibility. What's the best way to diagnose? Any things I should check out?
Thanks, Alastair
