Home > Maintenance & Modifications > Painting Stainless steel - advice please
Keith5
United Kingdom 2012 Defender 110 Puma 2.2 USW Santorini Black
I have had some brackets made to fix my foxwing awning onto a flatdog rax. The brackets are made from 316 so should be fine however their a bit shiny against the black of the rax.
Considering painting them rather than powder coating, do I need to think about specific primers before using a satin black spray?
Thanks Keith
Post #607007 5th Mar 2017 6:28pm
Key surface, acid etch primer, base, clear.
If you want a superb gloss finish it'd be key, acid etch, hi build / filler primer, dry sand with 600 grit then base, clear.
For large items there would be another step too a sealer on top of the hi build.
As the hibuild will take on quite a bit of paint.
Thumbs Up ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #607013 5th Mar 2017 6:41pm
zsd-puma
Sand blasting gives the best key i found.
Post #607040 5th Mar 2017 7:53pm
That maybe not possible though for the OP unless sent off, I certainly couldn't do it myself.
Panel wipe would also be useful. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #607061 5th Mar 2017 8:36pm
Ramsay
Scotland 1995 Defender 110 300 Tdi CSW Auto Keswick Green
Our work specifications (aerospace) call for a light bead blast before painting stainless steel surfaces. 1995 Defender 110 CSW
1971 SIIA Lightweight
Post #607077 5th Mar 2017 9:05pm
Is there ever any issues with pitting due to defects? ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #607087 5th Mar 2017 9:20pm
Keith5
Thanks for the suggestions so far.
Sand blasting is beyond what I can do. If I were to do that I would be as well getting it powder coated at the same time. Keith
Post #607099 5th Mar 2017 9:51pm
Balvaig
Bought stainless rear mud flap brackets for mine. Prepped with fine wet and dry, etch coated, primed and top coated in satin black. No problems despite harsh environment. A straightforward diy job.
Post #607164 6th Mar 2017 8:40am
