Home > My Defender > An Anoraks Tdi Defender 90
Page 7 of 24 <123 ... 678 ... 222324>
They're sitting in a box in the garage - haven't had chance to fit them yet Laughing Darren
Post #606789 4th Mar 2017 10:56pm
L110CDL
You will, one day Laughing Clayton.
Keeper.
Post #606790 4th Mar 2017 10:57pm
grafty99
Laughing Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #606797 4th Mar 2017 11:10pm
Ok, you've guilted me into it, so between the showers today I fitted these:
Also took the opportunity to fit a grill badge, although the picture is rubbish as it's parked nose in to my garage:
 Darren
Post #606955 5th Mar 2017 4:37pm
L110CDL
Much better LRA Thumbs Up Thats another couple little jobs out of the way and onto the next one Whistle Clayton.
Keeper.
Post #607045 5th Mar 2017 7:59pm
Finally fixed my reverse light yesterday by fitting a new gearbox switch:
A pleasantly easy job, for a change.
Also made a start on my rear work light control box:
This wil be fixed to the off-side rear light cluster panel and, with connections to side lights, reverse light and the purple constant live, will give me either fully automatic or manual switching. There will also be a 6 way fuse box inside the cluster panel that will feed the switchable DIN socket on the control box and a supply at roof level for my orange beacons.
Some of today was spent preparing various new holes in the light cluster panel and then both panels were given a fresh coat of paint:
I'll finish the wiring in the week and then hopefully get it all installed next weekend. Darren
Post #609027 12th Mar 2017 10:11pm
grafty99
Looking good! So what operating modes will you have with your lighting? 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #609030 12th Mar 2017 10:13pm
grafty99
I'm guessing on with reverse on when switched or off? 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #609033 12th Mar 2017 10:15pm
It's controlled by an on-off-on rocker switch. In auto mode, the work light will come on if reverse is selected and the side lights are on (so it won't come on in the daytime), but then it can be switched on manually from the rear when stationary. Darren
Post #609036 12th Mar 2017 10:19pm
grafty99
That sounds like a good plan Thumbs Up
Can the work lights be isolated so they don't come on even in reverse at night? 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #609040 12th Mar 2017 10:23pm
Yup. The centre 'off' position will disable the light completely. Darren
Post #609041 12th Mar 2017 10:24pm
grafty99
Very nice Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #609042 12th Mar 2017 10:27pm
Liam
Netherlands
That's a great setup. Have done the same with my work lights. Will also add a switch to operate it from the front
Post #609052 12th Mar 2017 11:29pm
Yeah, I did consider that but decided that the benefit wasn't worth the additional complexity. I couldn't think of any situation where being able to turn it on from up front would be more useful than doing so from the rear door. Darren
Post #609092 13th Mar 2017 9:04am
On the other hand, I did buy a wireless remote that I may wire in series, so that I can turn it on from outside. Darren
Post #609093 13th Mar 2017 9:05am
