Home > For Sale & Wanted > [SOLD] 2" Receiver and Drop Plate for 90 PUMA
Orangesofa
United Kingdom 2013 Defender 90 Puma 2.2 SW Keswick Green
NOW SOLD
Safari Equip 2" receiver and drop plate for 90 PUMA - never fitted.
This is still in the bubble wrap and due to change of plans, I am not going to fit it so it is for sale. These are £170 new from SE or Brendan of course. If someone is willing to collect or sort their own courier, I will see it gone for £150 (located near Wells in Somerset).
This is apparently what it looks like under the bubble-wrap (note: does not come with the billet recovery insert/shackle)
 Phil
Post #606457 3rd Mar 2017 4:17pm
I presume that it won't fit a 110?
If it fitted a 110, I'd buy it!
Post #606460 3rd Mar 2017 4:27pm
Orangesofa
I am happy to be told I am wrong but believe it is 90 only as you have to specify model when ordering.
Shame.... Phil
Post #606461 3rd Mar 2017 4:28pm
mick
Can't see why it won't fit
Post #606479 3rd Mar 2017 5:14pm
I imagine that the braces to the chassis legs are different to the 110, after all the DB adjustable towbar kits are different 110 to 90.
I am sure it could be adapted, but for the time taken etc it is probably more sense to buy the right one to start with.
Good luck with the sale! Thumbs Up
Post #606516 3rd Mar 2017 7:17pm
Orangesofa
Thumbs Up Phil
Post #606584 4th Mar 2017 6:57am
Mr Fudge
Is this still for sale?
Post #609990 17th Mar 2017 7:50am
Orangesofa
Yep. Thumbs Up Phil
Post #609997 17th Mar 2017 8:30am
Mr Fudge
Your not local so I couldn't collect, can you let me know the weight etc. and I can look into courier costs please?
Post #610012 17th Mar 2017 9:26am
If it helps, the box I received yesterday from Safari Equip containing the 110 version of this was labelled 8KG.
The difference between the 110 and 90 versions is, as we suspected, the length and shape of the two side braces.
Post #610024 17th Mar 2017 9:51am
Orangesofa
Well the box says 'Weight 10.00' but when it goes on the scales it is 16.8kg!
Box is 60cm x 30 x 20 if that helps with your quote. Phil
Post #610050 17th Mar 2017 12:11pm
Mr Fudge
Thanks - yes DPD give a reasonable price. Either you can drop off at a DPD collection place if there is one local to you, or I can arrange a courier collection.
If you PM me details for payment and courier (suspect they'll want a contact number), then I'll organise everything.
Alternatively if its easier for you to organise with DPD I'm happy to pay the courier charge.
Post #610052 17th Mar 2017 12:15pm
I thought it seemed excessively heavy for 8Kg as I carried it about half-a-mile from the courier's warehouse to the nearest parking space! Perhaps it said 16.8Kg but the "16." got covered in parcel tape. I feel better now, I thought that I was struggling a bit much for 8Kg!
Post #610059 17th Mar 2017 12:46pm
leeds
There are different versions of the 2" Receivers.
There are 4 variations
1) Defender 90 TDi
2) Defender 90 TD5/TDCi
3) Defender 110 TDi
4) Defender 110 TD5/TDCi
None available for Series Vehicles however it might be possible to adapt a later version
110 weighs in at just below 17 kg whereas the 90's weigh a smidgen over 16kg
Brendan
Post #610067 17th Mar 2017 1:22pm
mick
What about the 130 Neutral I fancy one
Post #610131 17th Mar 2017 7:02pm
