Home > In Car Electronics > LED Footwell Lighting
TechnoTurkey
2005 Defender 110 Td5 CSW Zambezi Silver
I've had a crazy thought that the easiest way to provide a little ambient light in the front footwells would be to just pop a small green LED on each side of the fusebox cover, taking an ignition switched live from inside the fusebox to power them.
Does this sound stupid or is there a better way?
Post #606438 3rd Mar 2017 2:43pm
AMBxx
Do you only want the light on when the ignition is running? I'd look at wiring into the door switches.
Post #606439 3rd Mar 2017 2:47pm
TechnoTurkey
I'd like them always on when the ignition is on, rather than with the doors.
It's nice when driving at night to have a little bit of colour in the vehicle, I have a 2017 E Class Merc which has all sorts of ambient lighting and love it!
Post #606441 3rd Mar 2017 2:59pm
discomog
I must be getting old - who on earth wants mood lighting in a vehicle when they are driving? Come to think of it maybe I should have installed it in my Triumph Herald 50 years ago for those romantic green lane sessions! Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #606445 3rd Mar 2017 3:22pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
"I must be getting old - who on earth wants mood lighting in a vehicle when they are driving? Come to think of it maybe I should have installed it in my Triumph Herald 50 years ago for those romantic green lane sessions!"
Thumbs Up
To be honest I would like to turn down the dash lights I'm sick of the reflection in the Glass Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #606446 3rd Mar 2017 3:38pm
ericvv
mcma on here installed mood lights in the footwell I believe.
As to myself, I recently installed footwell lights which come on and will fade off again with the other interior lights, but they do not stay on permanently as mood lights.
Reason I wanted those is that I often have to remove my Ardcase pedal lock, and in a pitch dark footwell I had blindly to search for the keyhole. With footwell lights which come on when the doors open, problem solved.
Wiring them into the door switches won't work. The door switches are only sending a signal to the 10AS, and the 10AS then sends the signal to the interior lights for these to come on and to fade off again. In my case the power for these footwell lights was taken from the center front interior ceiling light, wires run via the right hand side A-pillar and under the dash. Works perfectly. Pictures in my "2017 modifications" thread.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #606451 3rd Mar 2017 3:54pm
keith
What a waste of time ! I hate any light in the cab when driving at night . Infact I even have a pair of old socks sitting on the steering column to cover the light off the panel gauge lights .
Keith
Post #606452 3rd Mar 2017 3:57pm
Jim G
United Kingdom 1984 Defender 90 300 Tdi HT Stornoway Grey
Sounds like a good idea to me, but I think I would prefer red, I am sure you know to put a current limiting resistor in series with the LED's for 12v 1984 300TDi hardtop Stornoway Grey
1984 200TDi hardtop..... soon to be a V8 .. but which V8 ?
1974 DAF T244 4x4 wagon converted to a motorhome
1976 Jaguar XJC with supercharged engine
Post #606453 3rd Mar 2017 3:59pm
TechnoTurkey
I've got some 12v green LEDs kicking around anyway, I'll probably knock something up when I have a spare 5 minutes. I like green to match the dash.
At the end of the day I can remove it easily enough, might even use piggy back fuse take offs for the power.
Post #606456 3rd Mar 2017 4:14pm
Riverboy
2014 Defender 90 Puma 2.2 SW Corris Grey
I'd like my dash lights to be orange rather than cold green. I'd also like sparkly stars in the black Alcantara roof lining Smile
I'll stop there before some old Phart has a heart attack at the thought Whistle Laughing
Post #606459 3rd Mar 2017 4:25pm
Use a piggyback fuse tap on the lighter socket feed.
I would disconnect come MOT time though, and bear in mind if any coloured visible light is viewable from outside in transit it's be illegal. (I'd have thought anyway).
Mine is only on if I put it in with interior lights or
OE fading mimicking the LR's system.
I don't have it on whilst driving. KEEP CALM AND Drill ON
Post #606472 3rd Mar 2017 5:03pm
ericvv
Keith
Recently washed I hope. Rolling with laughter You never actually own a Defender. You merely look after it for the next generation.
Post #606483 3rd Mar 2017 5:28pm
Could have been his OH's Whistle KEEP CALM AND Drill ON
Post #606486 3rd Mar 2017 5:35pm
ericvv
Post #606488 3rd Mar 2017 5:43pm
keith
ericvv wrote:
Keith
They cover the bright dash lights .... but really there the spare pair that every defender driver should have for the inevitable wet feet syndrome after every rain storm. Whistle
Post #606493 3rd Mar 2017 6:03pm
