![]() | Home > Technical > Interior LED question |
Butchers Boy Member Since: 10 Jan 2016 Location: Essex Posts: 426 ![]() ![]() ![]() |
I have these bulbs
http://www.ebay.co.uk/itm/2-x-C5W-CAR-BULB...SwubRXKxNy I think they are the same as you are talking about? Try turning them around I'm sure that they have to go a curtain way around i.e take the bulb out of the fitting turn so the left side of the bulb now goes in to the right side of the fitting and the right in the left - hope that makes sense? ![]() The longer I live..... The better I was! |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1875 ![]() ![]() |
That makes perfect sense and mine are these http://www.ebay.co.uk/itm/161908173081?_tr...EBIDX%3AIT but same idea.
They didn't work at all until I turned them around as you suggest. But I don't think that solves my issue. They go on and off but also have a permanent glow in the middle switch position with the doors closed? Nice light though when they are on. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20613 ![]() ![]() |
Pretty sure it's due to low resistance.
You should check current draw at rest between a standard bulb and the new LED and compare. There will be a drastic difference in current draw between the standard light and an LED one. I have plenty of other LED's on my interior light feeds so brings the draw up but still slightly below normal operating current that the 10AS is used to detecting. How fast or slow is the dimming cut off of them? The lower the resistance the more steep the dimming will likely be, and faster. However, draw should never be more than the original bulb fixture. (I can't recall the draw and wattage it is now off the top of my head.) Chillin In The Backwoodsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
Really appreciate that, but to be honest not sure what to do with it as I can't use a meter
![]() The LED bulb goes from bright to dim as with the original bulb after a few seconds of closing the doors but then appears to stay dim indefinitely - it's been the same now for half an hour anyway. Guess you've not had this issue Butchers Boy? |
mark_d Member Since: 07 Sep 2013 Location: Northern Ireland Posts: 266 ![]() ![]() |
It appears the 10AS uses variable Pulse Width Modulation to gradually dim the interior lights. LEDs don't dim in a linear fashion when you use current control. http://defender90xs.blogspot.co.uk/ |
So, does that mean I have to go back to the original bulb?
Not really, I'd check the current being used and see what the figure is.
If it's under 5mA I wouldn't really worry, but the issue is you may get battery drain if left for a while. Perhaps a good idea to try a different type of LED's. I've never had the issue myself but some others have, not that common though that I'm aware of. What type of LED's is it using, regular or SMD chips? Dimming wise, that doesn't worry me. So long as they mimic standard use that's all that interests me, I've ran LED's in mine for years now with no issues at all. Chillin In The Backwoodsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
Don't worry about it, any electronic switch will have a little bit of leakage it's just you can notice it now.
It will be "wasting" the same amount of energy as it was before but you couldn't see it before. |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
I have these.
They work perfectly ![]() http://fourby.co.uk/epages/950004277.sf/en...oon%5B1%5D |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1042 ![]() ![]() ![]() |
I have the same problem with mine. Glad to see it's 'by design'!
I changed to LEDs after I left the internal light on for several days - call from tracker company telling me the battery voltage was below 5V. Shame they didn't tell me at 11V, but there you go. I don't think the amount of current is anything to worry about. I often leave my Defender a week or more without driving buy have had no battery problems. If anyone asks - you paid extra for the ambient light version, as fitted to all the posh makes. ![]() |
LinDens90XS Member Since: 24 Feb 2012 Location: Merseyside Posts: 83 ![]() ![]() |
I bought my festoon led from Halfords, must be over a year at least and no problems, have them on both interior lights. Regards
Dennis. |
Jim G Member Since: 21 Jul 2014 Location: Ormskirk Posts: 92 ![]() ![]() ![]() |
The problem you have is that there is a resistance across the switch when the switch is open, as the LED draws very little current it will still illuminate dimly
Probably due to water on the switch contacts with a little dust ( or mud) pull the door switches and clean and WD40 them, that will fix it |
The door switches have nothing to do with it, at least on a modern Defender.
All the door switches do is talk to the 10AS alarm unit, which then does all the control of the interior lighting. The glowing LEDs is a feature of the 10AS. |
Mine don't glow.
I'd put it down to having a low current load, I've tried to mimic the standard incandescent load or at least no lower than 400mA. It should all be wired in parallel too as per standard and not in series. Chillin In The Backwoodsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
