Home > Technical > Interior LED question
Page 1 of 3 123>
CarMan
I was going to install the Mud one in the Puma but didn't want to make four new holes in the headlining, so decided just to replace the bulb with an LED festoon, which arrived yesterday.
When the light switch is off the LED bulb goes off and when it's on the bulb lights, so far so good, but when the switch is in the middle position where it works with the doors opening the bulb just glows when the doors are shut Confused
Why Question Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
2016 2.2 XS 90 hard-top (sold)
Post #580556 26th Nov 2016 9:52am
Butchers Boy
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
I have these bulbs
http://www.ebay.co.uk/itm/2-x-C5W-CAR-BULB...SwubRXKxNy
I think they are the same as you are talking about?
Try turning them around I'm sure that they have to go a curtain way around i.e take the bulb out of the fitting turn so the left side of the bulb now goes in to the right side of the fitting and the right in the left - hope that makes sense? Thumbs Up 2010 Defender 90 HT
The longer I live..... The better I was!
Post #580580 26th Nov 2016 2:26pm
CarMan
That makes perfect sense and mine are these http://www.ebay.co.uk/itm/161908173081?_tr...EBIDX%3AIT but same idea.
They didn't work at all until I turned them around as you suggest. But I don't think that solves my issue.
They go on and off but also have a permanent glow in the middle switch position with the doors closed?
Nice light though when they are on.
Post #580582 26th Nov 2016 2:40pm
Pretty sure it's due to low resistance.
You should check current draw at rest between a standard bulb and the new LED and compare.
There will be a drastic difference in current draw between the standard light and an LED one.
I have plenty of other LED's on my interior light feeds so brings the draw up but still slightly below normal operating current that the 10AS is used to detecting.
How fast or slow is the dimming cut off of them?
The lower the resistance the more steep the dimming will likely be, and faster.
However, draw should never be more than the original bulb fixture.
(I can't recall the draw and wattage it is now off the top of my head.) $W33T $0U7H3RN $UG4R
Post #580587 26th Nov 2016 3:28pm
CarMan
Really appreciate that, but to be honest not sure what to do with it as I can't use a meter Embarassed
The LED bulb goes from bright to dim as with the original bulb after a few seconds of closing the doors but then appears to stay dim indefinitely - it's been the same now for half an hour anyway.
Guess you've not had this issue Butchers Boy?
Post #580594 26th Nov 2016 4:04pm
mark_d
2010 Defender 90 Puma 2.4 XS CSW Santorini Black
It appears the 10AS uses variable Pulse Width Modulation to gradually dim the interior lights. LEDs don't dim in a linear fashion when you use current control. http://defender90xs.blogspot.co.uk/
Post #580597 26th Nov 2016 4:22pm
CarMan
So, does that mean I have to go back to the original bulb?
Post #580604 26th Nov 2016 4:47pm
Not really, I'd check the current being used and see what the figure is.
If it's under 5mA I wouldn't really worry, but the issue is you may get battery drain if left for a while.
Perhaps a good idea to try a different type of LED's.
I've never had the issue myself but some others have, not that common though that I'm aware of.
What type of LED's is it using, regular or SMD chips?
Dimming wise, that doesn't worry me.
So long as they mimic standard use that's all that interests me, I've ran LED's in mine for years now with no issues at all. $W33T $0U7H3RN $UG4R
Post #580606 26th Nov 2016 4:55pm
Cupboard
Don't worry about it, any electronic switch will have a little bit of leakage it's just you can notice it now.
It will be "wasting" the same amount of energy as it was before but you couldn't see it before.
Post #580610 26th Nov 2016 5:13pm
Romadog
Post #580612 26th Nov 2016 5:19pm
AMBxx
I have the same problem with mine. Glad to see it's 'by design'!
I changed to LEDs after I left the internal light on for several days - call from tracker company telling me the battery voltage was below 5V. Shame they didn't tell me at 11V, but there you go.
I don't think the amount of current is anything to worry about. I often leave my Defender a week or more without driving buy have had no battery problems.
If anyone asks - you paid extra for the ambient light version, as fitted to all the posh makes. Thumbs Up
Post #581042 28th Nov 2016 9:44am
LinDens90XS
2003 Defender 90 Td5 XS CSW Bonatti Grey
I bought my festoon led from Halfords, must be over a year at least and no problems, have them on both interior lights. Regards
Dennis.
Post #581734 30th Nov 2016 7:31pm
Jim G
United Kingdom 1984 Defender 90 300 Tdi HT Stornoway Grey
The problem you have is that there is a resistance across the switch when the switch is open, as the LED draws very little current it will still illuminate dimly
Probably due to water on the switch contacts with a little dust ( or mud) pull the door switches and clean and WD40 them, that will fix it
Post #606143 2nd Mar 2017 7:03pm
Cupboard
The door switches have nothing to do with it, at least on a modern Defender.
All the door switches do is talk to the 10AS alarm unit, which then does all the control of the interior lighting. The glowing LEDs is a feature of the 10AS.
Post #606239 2nd Mar 2017 9:52pm
Mine don't glow.
I'd put it down to having a low current load, I've tried to mimic the standard incandescent load or at least no lower than 400mA.
It should all be wired in parallel too as per standard and not in series. $W33T $0U7H3RN $UG4R
Post #606244 2nd Mar 2017 10:00pm
Page 1 of 3 123>
