Home > Puma (Tdci) > Reprogramming an ECU
Page 5 of 5 <12345
A camshaft position sensor malfunction will (as far as I know) prevent the engine from starting, since the ECU can't determine whether the crankshaft is on a compression or exhaust stroke from the crankshaft sensor alone. Once the engine is running, the camshaft sensor isn't read, it's only used during the starting sequence.
Post #467625 29th Oct 2015 6:24pm
MK
PCM id
Sorry if asked before. Is the xx year 2.4 Transit PCM identical to a 2007 Defender PCM? I just need to make sure for "VCV , pilot, etc calibration purposes". Puma 110" SW
Post #606171 2nd Mar 2017 8:17pm
stobbie
Netherlands 2009 Defender 130 Puma 2.4 HCPU Fuji White
How did this end?
Post #690645 3rd Mar 2018 8:31pm
Page 5 of 5 <12345
