Home > Puma (Tdci) > Reprogramming an ECU
Page 4 of 5 <12345>
bell-auto-services
blackwolf wrote:
Pete will correct me if I am wrong, but most diagnostic tools should be able to check for Crankshaft and Camshaft Position Sensor output whilst cranking (and I am pretty sure that a DTC will be produced anyway). Certainly failure of either will prevent the engine starting. The camshaft sensor I believe is only used on startup, the crankshaft sensor is used all the time when the engine is running.
It does depend on what the ecu outputs if the can sensor is available on live data screen or not, but as you say it would produce a colleration error if it was not their and cause rpm signal faults on the crank sensor/rpm output in live data I suspect.
Pete
Post #462862 13th Oct 2015 12:24pm
RichieRich
2007 Defender 110 Puma 2.4 CSW Alpine White
Sorry Pete, I'm not doing this deliberately I was getting confused when you quoted me £250 for immobiliser removal and testing on your vehicle which you did and posted up a video. I was just reading through past comments to make sure I send over enough money to the UK so I wasn't short to pay you. Sorry!
Post #462867 13th Oct 2015 12:30pm
bell-auto-services
Your file has immobliser removed already so I can not really charge again for it, the original software file ill give you for free so all you need is the hardware for diagnostics and the file is free.
Post #462868 13th Oct 2015 12:32pm
bell-auto-services
Im sure someone is against me this week hehe.
Ive just been out to a call out to put to standard another car that has running issues and to code in a new VCV. I get to read the car out and find that "Dan the Man" has been their before me with his Transit ID software.
I then looked on the screen on the car and all the tell tail stickers are present of its source. It does seem dan the man should be renamed dan dan the geneic transit man.
Post #463227 14th Oct 2015 2:24pm
Pete, does this mean that you have now actually figured out who Dan the Man is? I appreciate that you may not want to identify him in public, but is he a UK based tuner (I use the term "tuner" loosely because I can't think of a better word, at least not one for a family forum)?
Post #463248 14th Oct 2015 4:27pm
bell-auto-services
Like the insurance advert,, oooh yes I certianly have.
UK based & very suprising to some is also relevent.
Ive also found out that the checksums of the files are incorrect stopping correct diagnosis as well as an attempt to stop overwrite and readout with other tools. Dirty tricks I think.
Post #463251 14th Oct 2015 4:36pm
RichieRich
The story continues...got the excellent diagnostic tool from Pete at Bell Auto Services and ran a fault check. Unfortunately this came back with 11 faults listed below! Does anyone have any comments/advice/thoughts on the codes? Maybe all these faults are common and related to one another?
P0115-17(2F)
P1402-16(2F)
P0110-15(2Cool
P0235-21(2F)
P2562-34(2F)
P0403-1B(2Cool
P0046-1B(2Cool
P0180-15(2Cool
P0645-23(2Cool
P068B-00(2Cool
P0623-13(2Cool
Any help on what I should do next would be very much appreciated!
Post #465845 23rd Oct 2015 3:54pm
RichieRich
Don't know what's going on with the smiley faces they should be a number 8!
Post #465846 23rd Oct 2015 3:55pm
bell-auto-services
Please email your self with the faults direct from the app it self and then paste the test here as this adds text info to the fault codes also which makes them easer to understand.
Do the same for the engine ecu infos
You also NEED to clear the faults, do some cranking, then RE read then as some could be left over from the ecu sitting powered on the bench !
Post #465853 23rd Oct 2015 4:06pm
RichieRich
So before I cleared the faults this is what came back
VIN: SALLDHMS87A740310
Vehicle scanned on 23-10-2015 14:55
Using BAS2 V1.0 B2482
PCM-Engine Puma 2.4
P0115-17 (2Cool Engine coolant temperature sensor 1 - circuit - General electrical failure - circuit voltage above threshold
( at 477 mi )
P1402-16 (2Cool Exhaust gas recirculation - metering orifice restricted/valve position sensor circuit - General electrical failure - circuit voltage below threshold
( at 477 mi )
P0110-15 (2Cool Intake air temperature sensor circuit - General electrical failure - circuit short to battery or open
( at 477 mi )
P0235-21 (2Cool Turbocharger/ supercharger boost sensor A circuit - General signal failure - signal amplitude<minimum
( at 477 mi )
P2562-34 (2Cool Turbocharger boost control position sensor A circuit - Frequency modulation/pulse width modulation failure - signal high time<minimum
( at 477 mi )
P0403-1B (2Cool Exhaust gas recirculation control circuit - General electrical failure - circuit resistance above threshold
( at 477 mi )
P0046-1B (2Cool Turbo/supercharger boost control solenoid - circuit range/performance - General electrical failure - circuit resistance above threshold
( at 477 mi )
P0180-15 (2Cool Fuel temperature sensor A circuit - General electrical failure - circuit short to battery or open
( at 477 mi )
P0645-23 (2Cool Air conditioning clutch relay control circuit - General signal failure - signal stays low
( at 477 mi )
P068B-00 (2Cool Engine control module/powertrain control module - power relay de-energized too late
( at 477 mi )
P0623-13 (2Cool Generator lamp circuit - General electrical failure - circuit open
Cleared the faults, cranked over few times then re read faults and it came back with no faults!? Hmm! ECU info below.
Vehicle scanned on 23-10-2015 14:58
PCM-Engine Puma 2.4
Assembly 7H12-12C520-BK
Hardware 7H12-12B684-AA
Strategy 7H12-12K532-FCE
Calibration 7H12-12K532-FCE
Injector 1 F000001200000DEF
Injector 2 F0E3000F0000001C
Injector 3 F000141F001B15F5
Injector 4 F40000E8EFEF001C
Serial YBEWF2AN7P42
VIN 013047A78SMHDLLAS
Now I'm confused as no faults logged at all?!
Post #465887 23rd Oct 2015 5:10pm
bell-auto-services
Perfect,, one step at a time now we will try work out whats wrong with it. As said those faults will bwe remaining mostly from bench testing.
Follw othis video and update the tool by pressing program flash files in the PC/MAC App https://secure.bellautoservices.co.uk/help...date-tool/
NOTE, The tool is ONLY connected to the PC/MAC or to the car, its NEVER connected to both at the same time.
Once you have updated the tool with the updater software connect back to the car and look in the ECU Flash menu, you have 2 files waiting, select the IMMO one and follow the onscreen.
Post #465893 23rd Oct 2015 5:19pm
RichieRich
Done that Pete, what's next?
Post #465904 23rd Oct 2015 6:30pm
RichieRich
Updated tool with latest ECU flash, followed onscreen instructions, cranked out and read live data engine RPM around 174 and fuel pressure 157,000!
Post #465906 23rd Oct 2015 6:57pm
bell-auto-services
Try the tow start we spoke about, if it does not start WITHOUT turning the key off read the fault codes on that same key cycle.
Post #466598 26th Oct 2015 9:26am
RichieRich
Just to keep the thread going so everyone can follow what's been happening. I tried to tow start reading the live data from Pete's diagnostic tool and had the RPM up around 1000 when lifting the clutch in 3rd gear. Engine didn't start but was good to see the RPM a lot higher than when cranking over when stationary.
Kept the key on, read faults, no faults recorded. Towed back to the house and last couple of days unscrewed nuts to the injectors to make sure fuel was getting up to them. All four injectors were getting fuel. Cranked over a few times, checked faults, no faults recorded other than a camshaft position sensor fault which was pretty weird as this had never showed up before.
Cleared faults, cranked over some more (it's soooo close to starting but just won't take!!) read faults, no faults recorded.
So next step I'm going to add more fuel to the tank as what is in it has been there for 2 years(!!) and order a VCV and swap that then see what happens after the new VCV has been programmed in with Pete's great little tool!
With any luck next post will be I'm up and running but not getting too excited until Bubba actually starting first time and running smoothly!
Huge thanks to Pete for all his help and patience so far to date!!
Post #467589 29th Oct 2015 5:30pm
Page 4 of 5 <12345>
