![]() | Home > Td5 > TD5 Turbo |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2193 ![]() ![]() |
If you fit a hybrid you'll have to have it remapped to get the most out of the new turbo. Fine with a snorkel they just restrict air flow. Open up your airbox and remove the impeller, should help the air flow better
[URL=] ![]() Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
I agree on the impeller but I don't think that the part you cut out is the biggest restriction. In front off the pedal box is a water seperator that is not even 65mm internal diameter while the part you cut out is almost 80mm. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
True! Just a quick pic i grabbed off google, remove the lot for max air flow. You can see in the photo the impeller is missing
