Home > Td5 > TD5 Turbo
Tank
Scotland 2004 Defender 90 Td5 HT Zermatt Silver
TD5 Turbo
Question.
I have a 2004 TD5 90 with 179,000 on the clock. I have taken the exhaust manifold and turbo off as I had some type of leak, maybe the manifold gasket. Anyway, while the turbo is off I am thinking it must be tired, it looks it! Do I therefore buy a reconditioned one (any recommendations) or do I buy a hybrid one.
I run a Stage 2 tune with AlliSport intercooler, de-cat, EGR removed but I have a snorkel!!! Everyone seems to say not to run a hybrid with a snorkel?
Advice please ?
Thanks
Post #605703 1st Mar 2017 9:38am
bankz5152
If you fit a hybrid you'll have to have it remapped to get the most out of the new turbo. Fine with a snorkel they just restrict air flow. Open up your airbox and remove the impeller, should help the air flow better
[URL=][/URL]
Post #605725 1st Mar 2017 11:27am
roel
I agree on the impeller but I don't think that the part you cut out is the biggest restriction. In front off the pedal box is a water seperator that is not even 65mm internal diameter while the part you cut out is almost 80mm. Roel
2003 90 Td5 (2009-now)
Post #605802 1st Mar 2017 5:58pm
bankz5152
True! Just a quick pic i grabbed off google, remove the lot for max air flow. You can see in the photo the impeller is missing
Post #605883 1st Mar 2017 9:02pm
