Home > Puma (Tdci) > Is it hailing outside? Yes... the alarms going off again
tobz102
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Anyone else alarm go off during heavy hail shower? Currently occurring in the midlands and for the second time the alarm has gone off. Last time it happened I cleaned all my door sensors thinking it was rain getting in and shorting, but it's happened again this time. Beginning to think the vibration from hitting against my none insulated HT is playing with the ultrasonic sensor
Post #605287 27th Feb 2017 4:24pm
It'll be the sensor, although mine hasn't done it.
Do you have any rear headlining? ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #605291 27th Feb 2017 4:46pm
zsd-puma
The sensor is basically a sonar, the noise on the roof will fool it. Just like reversing beepers and alarms can fool parking sensors.
Sticking 3 or 4 deadening pads on the inside of your tin roof will help (you don't have to cover the whole thing with them)
Then if you want to go a bit further cover the deadening pads and the whole inside of the roof with 6mm closed cell foam.
That'll have the added benefits of improving the noise levels when driving and offer better thermal insulation too.
Post #605445 28th Feb 2017 12:27am
tobz102
Thanks for replies, food for thought. Probably end up trying to insulate it somehow...
Post #605468 28th Feb 2017 8:27am
dorsetsmith
Check that your ultrasonic sensor is dry and water loge had same problem with my pick, condensation inside metal roof panel dripping down onto the back ultrasonic sensor short it out and trigging alarm
Post #605472 28th Feb 2017 9:11am
