Home > Puma (Tdci) > Is it hailing outside? Yes... the alarms going off again |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20322 |
It'll be the sensor, although mine hasn't done it.
Do you have any rear headlining? ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️ |
27th Feb 2017 4:46pm |
The sensor is basically a sonar, the noise on the roof will fool it. Just like reversing beepers and alarms can fool parking sensors.
Sticking 3 or 4 deadening pads on the inside of your tin roof will help (you don't have to cover the whole thing with them) Then if you want to go a bit further cover the deadening pads and the whole inside of the roof with 6mm closed cell foam. That'll have the added benefits of improving the noise levels when driving and offer better thermal insulation too. |
28th Feb 2017 12:27am |
tobz102 Member Since: 07 Feb 2014 Location: Atherstone Posts: 134 |
Thanks for replies, food for thought. Probably end up trying to insulate it somehow...
28th Feb 2017 8:27am |
Check that your ultrasonic sensor is dry and water loge had same problem with my pick, condensation inside metal roof panel dripping down onto the back ultrasonic sensor short it out and trigging alarm
28th Feb 2017 9:11am |
