Home > Puma (Tdci) > Another rattle.
neverin
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Another rattle.
Hello again, there is a rattle coming from just in front of the gear stick but under the floor. It is loud when the engine is cold, but quietens down when the engine is warmed up.
It is definately a bearing rattle, with my limited knowledge is taht where the transfer box is? the clutch also rattles but this seems to be a different noise, maybe the are related?
it is a 2010 110 xs 84000 miles
Post #605283 27th Feb 2017 4:12pm
tobz102
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
if you press you clutch pedal does it go away?
Post #605286 27th Feb 2017 4:21pm
neverin
if i press the clutch then the clutch rattle almost goes away.
This other bearing noise is heard whilst accelerating from cold.
Post #605293 27th Feb 2017 4:58pm
Roy5695
The weights on the bottom of the gear stick possibly? there's a thread in the puma part of the page that may help... 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #605309 27th Feb 2017 6:45pm
neverin
its sounds under the car probably transfer box area?
Post #605511 28th Feb 2017 12:54pm
