![]() | Home > Puma (Tdci) > Another rattle. |
tobz102 Member Since: 07 Feb 2014 Location: Atherstone Posts: 134 ![]() ![]() ![]() |
if you press you clutch pedal does it go away?
neverin Member Since: 26 Sep 2016 Location: worksop Posts: 47 ![]() ![]() ![]() |
if i press the clutch then the clutch rattle almost goes away.
This other bearing noise is heard whilst accelerating from cold. |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
The weights on the bottom of the gear stick possibly? there's a thread in the puma part of the page that may help... 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp Roy |
its sounds under the car probably transfer box area?
