Home > Off Topic > Heat shrink cable connectors |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5111 |
If they look like these then yes you crimp then heat up the sleeve, inside is adhesive lined so once heated and shrunk it makes the connector waterproof.
For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
25th Feb 2017 2:37pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4219 |
The ones I have, have a solder ring inside, you heat the whole lot up until the solder melts, the glue melts and sleeve shrinks, no crimping. i use a small gas torch for heating it. 2007 110 TDCi Station Wagon XS
25th Feb 2017 2:51pm |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1309 |
Any recommendations for a decent small gas torch?
Having Creme brule for dinner |
25th Feb 2017 3:03pm |
After a bit more research it appears that there are two types, crimp and heat shrink and heat shrink and solder connectors its just a case now of working out which is which. Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to us off. Richard |
25th Feb 2017 3:14pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20499 |
Yes, this one: http://www.screwfix.com/p/dremel-f0132000j...0wodoCYGeQ Those heatshrink connectors, personally I don't like them at all. Better off just soldering and then heatshrink. I oersolly don't like any clear / see though electrical connectors, but that is just me. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
25th Feb 2017 4:01pm |
Thanks Steve
25th Feb 2017 4:19pm |
Best one I've had, it also has a live torch flame with variable pressure flow.
You would be pleased if you purchased. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
25th Feb 2017 4:37pm |
They are probably not in at the minute, but I have the Aldi version of that Dremel, I think it was half that price. Have used it loads and it works a treat. TBH even at the Dremel price they are great handy tool. 2007 110 TDCi Station Wagon XS
25th Feb 2017 6:01pm |
I already have the Portasol Technic for soldering
Dremel looks good - wish I had got that instead but I have had the Portasol for years and its a great soldering iron. |
25th Feb 2017 8:58pm |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 502 |
Adhesive-Lined Heatshrink Butt Connector and two cables �
Click image to enlarge Strip the ends of the cables to be joined � Click image to enlarge Insert the stripped cable ends into the Butt Connector from each side � Click image to enlarge Click image to enlarge Crimp each cable into the Butt Connector using a suitable Crimping Tool � Click image to enlarge Finished crimps � Click image to enlarge Heat the Heatshrink Sleeving until it�s shrunk and the Adhesive flows out � Click image to enlarge Finished joint � Click image to enlarge Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
26th Feb 2017 11:59pm |
