Home > Off Topic > Heat shrink cable connectors
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
I have not come across these before but I received some in a package from Mobile Centre the other day and haven't got a clue how to use them.
Has anyone used these connectors if so how do they work, is just heat up and shrink to out side, crimp then heat up ? Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #604734 25th Feb 2017 2:29pm
gilarion
If they look like these then yes you crimp then heat up the sleeve, inside is adhesive lined so once heated and shrunk it makes the connector waterproof.
 For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #604736 25th Feb 2017 2:37pm
Bluest
The ones I have, have a solder ring inside, you heat the whole lot up until the solder melts, the glue melts and sleeve shrinks, no crimping. i use a small gas torch for heating it. 2007 110 TDCi Station Wagon XS
Post #604740 25th Feb 2017 2:51pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Any recommendations for a decent small gas torch?
Having Creme brule for dinner
Post #604746 25th Feb 2017 3:03pm
ARC99
After a bit more research it appears that there are two types, crimp and heat shrink and heat shrink and solder connectors its just a case now of working out which is which. Don't make old people mad.
Richard
Post #604747 25th Feb 2017 3:14pm
Yes, this one: http://www.screwfix.com/p/dremel-f0132000j...0wodoCYGeQ
Thumbs Up Thumbs Up
Those heatshrink connectors, personally I don't like them at all.
Better off just soldering and then heatshrink.
I oersolly don't like any clear / see though electrical connectors, but that is just me. No Guts, No Glory.
Post #604757 25th Feb 2017 4:01pm
kmac
Thanks Steve
Post #604766 25th Feb 2017 4:19pm
Thumbs Up Best one I've had, it also has a live torch flame with variable pressure flow.
You would be pleased if you purchased. Thumbs Up No Guts, No Glory.
Post #604771 25th Feb 2017 4:37pm
Bluest
They are probably not in at the minute, but I have the Aldi version of that Dremel, I think it was half that price. Have used it loads and it works a treat. TBH even at the Dremel price they are great handy tool. 2007 110 TDCi Station Wagon XS
Post #604793 25th Feb 2017 6:01pm
kmac
I already have the Portasol Technic for soldering
Dremel looks good - wish I had got that instead but I have had the Portasol for years and its a great soldering iron.
Post #604846 25th Feb 2017 8:58pm
PaulMc
Adhesive-Lined Heatshrink Butt Connector and two cables �
Strip the ends of the cables to be joined �
Insert the stripped cable ends into the Butt Connector from each side �
Crimp each cable into the Butt Connector using a suitable Crimping Tool �
Finished crimps �
Heat the Heatshrink Sleeving until it�s shrunk and the Adhesive flows out �
Finished joint �
 Paul.
Post #605165 26th Feb 2017 11:59pm
