Home > Puma (Tdci) > Help! loss of power when shift to 4th gear
Eduardo
Hi there,
My wife is right now with the Defender in an isolated gravel road going to the farm and she have the following problem.
When she try to shift to 4th gear the Defender (Puma 2.4 MY2007) suddendly loss the power and the revs going down to 800 RPM. Temperature according the ODBII reader are in the 88-90�C level. She already check all the fuses and the battery cables and all looks OK. Now she is going to purge the water from the fuel filter but i�m run out ideas about what can be.
Any thoughts?
Thanks in advance Eduardo
Post #603359 20th Feb 2017 7:10pm
agentmulder
Kuwait
It's unlikely that 4th gear has much to do with the fault moving forward (unless you're saying it only happens when you change to 4th???).
Great that you have a diagnostic reader, first step = check for faults. Solved the bowel problem, working on the consonants...
Post #603364 20th Feb 2017 7:53pm
diduan
Bulgaria
Sounds like EGR to me...
Post #603366 20th Feb 2017 7:59pm
EGR does indeed tend to affect higher gears more, it seems almost as if there is a parasitic load when accelerating in higher gears. WeWillWin🇬🇧🇺🇸
Post #603367 20th Feb 2017 8:01pm
Eduardo
Well,
Thanks for the fast answer.
EGR is void thorugh a BAS Remap and no DTC's codes appear in the log.
The problems happens when she moves from 3rd to 4th gear.
In any case, appears to be water in the diesel.
After three purges (lot of water in it) the problem almost dissapear and she was able to reach the farm.
She will proceed to purge again there (she load diesel in an isolated station in the road and may be its the culprit Evil or Very Mad).
Probably the 4th gear requires more power (diesel) and with the amount of water the engine doesnt recive enough diesel to work.
Cheers! Eduardo
Post #603371 20th Feb 2017 8:38pm
VCV
Post #603374 20th Feb 2017 8:45pm
Eduardo
Humm, could be...
I have the spare with me right now and when she comback i will do it.
Cheers! Eduardo
Post #603381 20th Feb 2017 8:56pm
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
Eduardo, whatever the Landy problem turns out to be, your wife is definitely a keeper! Thumbs Up 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MT�s,
Recaro CS�s, anorak, wellingtons
Post #603387 20th Feb 2017 9:05pm
Eduardo
Laughing Laughing Laughing
A tough lady,
A forest engineer that use to be in isolated gravel roads (one reason to have a Defender) Thumbs Up Eduardo
Post #603458 20th Feb 2017 11:42pm
