![]() | Home > Puma (Tdci) > Help! loss of power when shift to 4th gear |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 ![]() ![]() ![]() |
Hi there,
My wife is right now with the Defender in an isolated gravel road going to the farm and she have the following problem. When she try to shift to 4th gear the Defender (Puma 2.4 MY2007) suddendly loss the power and the revs going down to 800 RPM. Temperature according the ODBII reader are in the 88-90�C level. She already check all the fuses and the battery cables and all looks OK. Now she is going to purge the water from the fuel filter but i�m run out ideas about what can be. Any thoughts? Thanks in advance Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
diduan Member Since: 13 Oct 2016 Location: Central Balkan Posts: 260 ![]() ![]() |
Sounds like EGR to me...
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20715 ![]() ![]() |
EGR does indeed tend to affect higher gears more, it seems almost as if there is a parasitic load when accelerating in higher gears. WeWillWin🇬🇧🇺🇸
Well,
Thanks for the fast answer. EGR is void thorugh a BAS Remap and no DTC's codes appear in the log. The problems happens when she moves from 3rd to 4th gear. In any case, appears to be water in the diesel. After three purges (lot of water in it) the problem almost dissapear and she was able to reach the farm. She will proceed to purge again there (she load diesel in an isolated station in the road and may be its the culprit ![]() Probably the 4th gear requires more power (diesel) and with the amount of water the engine doesnt recive enough diesel to work. Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge Last edited by Eduardo on 20th Feb 2017 8:54pm. Edited 1 time in total |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17686 ![]() ![]() ![]() |
VCV
Humm, could be...
I have the spare with me right now and when she comback i will do it. Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 ![]() ![]() ![]() |
Eduardo, whatever the Landy problem turns out to be, your wife is definitely a keeper!
![]() 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MT�s, Recaro CS�s, anorak, wellingtons |
![]() ![]() ![]() A tough lady, A forest engineer that use to be in isolated gravel roads (one reason to have a Defender) ![]() MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
