![]() | Home > In Car Electronics > TD5 earth points |
If you download the rave disc you can find all connectors and earth points. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
rave link below Big file 460MB
https://1drv.ms/f/s!AtZSoWFHDgnGhVAVkjMw1okIBsad |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5884 ![]() ![]() ![]() |
Cheers chaps. Download on the way 1999 Defender TD5 110
The first one I got before the link from dorsetsmith appeared to be just for the NAS spec Defender? Didnt see a mention of TD5. So now going for the dorsetsmith link 1999 Defender TD5 110
Khauff Member Since: 15 Jan 2017 Location: Scotland Posts: 10 ![]() ![]() |
Check the earth points in the inner wing
Earth points in the inner wing...Ok, will have a look. Which side? 1999 Defender TD5 110
Apologies, I did see that listed in the RAVE this morning. Need to spend a few hours tracing cables.
Cheers 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
huffhuff Member Since: 05 May 2016 Location: Home Counties Posts: 379 ![]() ![]() ![]() |
My water in fuel light used to come on. My filter didn't have the plug connected, so it was filling with mud and crud and making it flash intermittently. I cleaned it out, heatshrinked it up and it's not happened again. TD5 Defender 90
Discovery 3 HSE |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 ![]() ![]() ![]() |
Dorsetsmith ![]() Excossack - I hope you trace and rectify the fault - best of luck ![]() |
no need its big file to work through ![]() |
I hope I find it but will take some time as next weekend is another rally. 1999 Defender TD5 110
