Home > Technical > Which crossmember??
orkneydave
Which crossmember??
My son has recently discovered that his gearbox crossmember is made of hammerite and sand!! Shocked Shocked
Its a 1986 ex MOD 110 (formerly soft top) that came with a 19J but he has recently fitted a 300tdi.
I have found various listings for replacement crossmembers but none for a 110 so early. Any ideas?
I also guess the chassis rails where the crossmember touches will be a touch tender too!
Post #601622 13th Feb 2017 9:34pm
jst
I believed it would of been one of those round cross members initially. A flat type 300 one or td5 one will fit I believe Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #601683 14th Feb 2017 7:47am
orkneydave
Thanks James, that's what I thought but was starting to doubt myself. Thumbs Up
Post #601686 14th Feb 2017 7:56am
walfy
I'm sure I have a flat style crossmember in the back of the garage somewhere if needed Thumbs Up 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #601745 14th Feb 2017 11:32am
NickMc
Is he using the LT77 gearbox still? Round and square type including td5/ Tdci are nearly all the same, only bit is a Tdci has that stupid mount for absolutely no reason in the middle of it, which 2 minutes with a grinder will fix, tend to find these come up a bit cheaper. If he's fitting the R380 box you can use the 300Tdi discovery crossmember with a little bit of trimming too, either on the crossmember itself or the seat box "saddles" that the front M6 bolts fit through.
Post #603226 20th Feb 2017 12:44am
orkneydave
Thanks for all the replies Bow down
Yes he's still using the LT77 box. I did suggest he used the R380 but he seems happy with what hes got, although he may change the transfer box shortly.
Walfy, if you have a crossmember spare that would be great. I'll send you a PM. Thumbs Up
Post #604227 23rd Feb 2017 5:03pm
