Page 982 of 1382 <123 ... 981982983 ... 138013811382>
boode
England 2003 Defender 90 Td5 HT Rutland Red
From this
To this
Installed extra 4 switches below the radio - two for seat heaters, one for a permanent SatNav feed and one spare
Post #599541 6th Feb 2017 12:25pm
Well that's quite a nest of wiring. Laughing Chillin In The Backwoods🇬🇧🇺🇸
⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #599544 6th Feb 2017 12:31pm
Doc P
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
boode wrote:
From this
To this
Boode - that's not orange is it Shocked ?
Post #599624 6th Feb 2017 5:28pm
boode
Doc P
Its LandRover Rutland Red - just a bad photo
Post #599654 6th Feb 2017 6:53pm
leonvh
Belgium 2013 Defender 110 Puma 2.2 SW Barolo Black
Washed it as the snow is finally gone...
... and added some power to the music!
Post #600902 11th Feb 2017 9:54am
Brendlynch
Jersey 2005 Defender 110 Td5 XS CSW Cairns Blue
Lovely truck
Post #600923 11th Feb 2017 12:04pm
L110CDL
+1 Thumbs Up Clayton.
Keeper.
Post #601047 11th Feb 2017 9:13pm
excossack
Yesterday went to the Cambrian rally to do recovery. Stages/Event got cancelled due to snow.
At the Llangower stage
 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #601215 12th Feb 2017 4:59pm
Liam
Netherlands
weekend project with my eldest son: added 2 labcraft si7 worklights to the back, with some nice complicated switching:
- off
- on
- on when reversing, but only if I have the regular lights on. Nice combination of 2 relays.
Still need to add a switch from the front.
Next projects: Puma clutch spring & Landreiziger cruise control. Should be fun!
Post #601228 12th Feb 2017 5:36pm
What's the Puma clutch spring? Do you mean a modified type? Chillin In The Backwoods🇬🇧🇺🇸
Post #601245 12th Feb 2017 6:06pm
excossack
While trying to trace an possible earth fault, I removed the speedo dash section. Discovered why the blowers are no good and there is a lack of heat. The tube that feeds the top dash air vent was not sitting in the rubber boot at the bottom of the dash. After much fiddling I managed to get the tube to sit in the rubber boot.
Also, as I had the dash in bits. I investigated the vent control flaps not working properly. Turns out the cable clamp was not clamping the cable and allowing the cable to slip and rub on the bottom on the dash.
Now instead of three positions available, there are now only two. Top click and 2nd click. No amount of adjusting gave me the 3rd click. Maybe cable too short? 1999 Defender TD5 110
Regards
John M0VAZ
Post #601257 12th Feb 2017 6:38pm
Liam
Netherlands
Exactly
Post #601258 12th Feb 2017 6:39pm
Leeroy
United Kingdom 2016 Defender 110 Puma 2.2 Adventure Phoenix Orange
Dad and lad out snow chasing Laughing Laughing Laughing
Post #601260 12th Feb 2017 6:45pm
excossack
@Liam - Exactly - Cable too short? 1999 Defender TD5 110
Regards
John M0VAZ
Post #601261 12th Feb 2017 6:45pm
Cactus79
Filled the clutch master the other week when the clutch wouldn't engage. Went to drive it on Sat night to find couldn't engage first.
Double checked peddle to find oil dripping down so refilled and bleed clutch again to keep it going for another week to order a clutch master tomorrow for the weekend.
Also noted power steering pump weeping way too much which will need sorting.
Duckworth will be on speed dial soon.
Post #601285 12th Feb 2017 7:32pm
