Home > In Car Electronics > Wiring diagram please
GSLRO
United Kingdom 2002 Defender 110 Td5 CSW Chawton White
Looking to fit this in the back of the 110 what is the best way to wire it up?
The cigarette lighter, usb and 12v meter all have two connectors + and -, the switch has 3 connectors and is two way on / off with no lables apart from one brass connector and two chrome connectors.
Please bear in mind I am a reasonable novice but want to have a go myself.
Thanks in anticipation!
George Thumbs Up
 Adventure isn't paved!
Post #601188 12th Feb 2017 3:02pm
Laurie
Have you got tow sockets fitted?
Post #601200 12th Feb 2017 4:00pm
VeeTee
Netherlands
The + and - connections of the cigarette lighter, usb and meter speak for themselves I think, I guess the switch brass connector is to provide earth for when the switch is in the on position and the led lights up. Check polarity with multimeter. Where you take the feed from is dependend on where you want to fit it. There is a permanent live (purple) behind the speakerpanel on the right side in the back. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #601201 12th Feb 2017 4:09pm
GSLRO
I have a perm live and an ignition live to the back of the 110 Thumbs Up Adventure isn't paved!
Post #601207 12th Feb 2017 4:41pm
GSLRO
As mentioned above I have two power sources permeant live and ignition live so ok with that.
Just wondering if your connect all the +'s together and the -'s together and them connect them to the respective feeds. Or loop the wires + / - / + / - / + /-
Found out that the switch is two chrome connectors + pos in and + out. The brass contact is for the led (I hope).
Thanks for ALL the replies Thumbs Up Adventure isn't paved!
Post #601211 12th Feb 2017 4:46pm
VeeTee
Netherlands
Depends a bit what you want to do with the panel...
One way is to take the permanent live to the swich + and from there (-) to the + of the lighter, usb and meter. Then connect the - of the lighter, usb and meter (and the brass connector of the switch) to an earth point.
This way you use the switch to activate the lighter, usb and meter. And so you can use the lighter, usb and meter independ of the ignition on.
There are other ways off course to do this - this is how I would do this ... In fact, I have the same panel lying in the garage waiting to be installed - this way... Whistle Cheers, Vincent
MySite
Post #601229 12th Feb 2017 5:38pm
