Home > Tdi > Ashcroft higher 5th gear option on R380 |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4786 |
I have the taller 5th on my Td5, with the disco/puma transfer box it makes high speed cruising effortless. I believe that the taller 5th is 5% taller than standard so with a defender transfer box it would make a 150rpm difference at 3000 rpm.
Every little helps 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
12th Feb 2017 8:19am |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2185 |
Yes. Depending on how much power you bav available you may have to shift down on motorway hills. Otherwise excellent.
12th Feb 2017 8:45am |
MJN110 Member Since: 18 May 2015 Location: North Yorkshire Posts: 380 |
Hi
I would have no hesitation if I had a TD5 as it has more power and torque. |
12th Feb 2017 9:07am |
I would have thought a standard Tdi could cope with a 5% top gear increase. After all the Tdi is fitted to the disco which is much heavier and has 18% or so taller gearing 2002 90 Td5 Station Wagon
12th Feb 2017 9:27am |
And smaller tyres. Darren
12th Feb 2017 9:59am |
Are the tyres smaller than 235/85 R16?
12th Feb 2017 11:11am |
I almost did go for the taller fifth gear option, however was advised not to by Ashcrofts as I already had a disco transfer box. Even with a remapped ECU.
I did however opt for the updated bearings though |
12th Feb 2017 11:12am |
Yes 235/70/16 |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 716 |
I've recently fitted an Ashcroft box with a v8 5th gear ratio and am very pleased with the difference. In conjunction with 285/75 tyres it makes motorway speeds significantly quieter although that is in a TD5.
If you have an uprated I/C already then why not turn the boost and fuelling up a touch? That would help pull the gearing increase on motorway hills. |
12th Feb 2017 1:17pm |
Yes i was planning on adjusting the pump and boost.
12th Feb 2017 8:57pm |
I was hoping that somebody with a 300tdi with the higher 5th gear option would have responded.
Maybe nobody has opted for it? |
22nd Feb 2017 10:49am |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1764 |
I have a TD5 with the higher 5th and very happy with it.
A friend has a 300tdi with a 1.2 Tbox and is very happy with it, thought it is slower off the line. Based on that, I'd say you'd have no issues with the v8 5th in a 300tdi! |
22nd Feb 2017 11:32am |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 |
I have a 300Tdi with R380 box with 5th gear, Td5 transfer box. Great on motorways but need to be over 35-40 before changing up otherwise it labours. A Slickshift makes gear changing much easier. Jeff
Ex 1968 Series 2A Ex 90 TD5 Ex D3 Ex D4 |
22nd Feb 2017 5:54pm |
When you say you have a td5 transfer box are they not the same as a 300tdi? Or do you mean you have a 1.2 ratio transfer box like a disco combined with the higher 5th gear option from ashcroft?
22nd Feb 2017 9:35pm |
