Home > Tdi > Ashcroft higher 5th gear option on R380
Page 1 of 3 123>
MJN110
United Kingdom 2016 Defender 90 Puma 2.2 Landmark LE Montalcino Red
Hi
I am planning on installing a replacement R380 gearbox to my 1997 Defender 90 300 tdi.
Should I go for the higher 5th gear option?
I was planning on running the car with 235/85 R16 tyres as it feels to low geared on the standard tyre sizes.
The only engine upgrade I have is a double core intercooler.
Any input would be much appreciated.
Thanks
Post #601105 12th Feb 2017 7:43am
grafty99
I have the taller 5th on my Td5, with the disco/puma transfer box it makes high speed cruising effortless. I believe that the taller 5th is 5% taller than standard so with a defender transfer box it would make a 150rpm difference at 3000 rpm.
Every little helps Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #601113 12th Feb 2017 8:19am
bankz5152
Yes. Depending on how much power you bav available you may have to shift down on motorway hills. Otherwise excellent.
Post #601119 12th Feb 2017 8:45am
MJN110
Hi
I would have no hesitation if I had a TD5 as it has more power and torque.
Post #601128 12th Feb 2017 9:07am
grafty99
I would have thought a standard Tdi could cope with a 5% top gear increase. After all the Tdi is fitted to the disco which is much heavier and has 18% or so taller gearing Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #601132 12th Feb 2017 9:27am
And smaller tyres. Darren
Post #601140 12th Feb 2017 9:59am
MJN110
Are the tyres smaller than 235/85 R16?
Post #601149 12th Feb 2017 11:11am
geobloke
I almost did go for the taller fifth gear option, however was advised not to by Ashcrofts as I already had a disco transfer box. Even with a remapped ECU.
I did however opt for the updated bearings though Thumbs Up
Post #601150 12th Feb 2017 11:12am
geobloke
Yes 235/70/16
Post #601151 12th Feb 2017 11:12am
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
I've recently fitted an Ashcroft box with a v8 5th gear ratio and am very pleased with the difference. In conjunction with 285/75 tyres it makes motorway speeds significantly quieter although that is in a TD5.
If you have an uprated I/C already then why not turn the boost and fuelling up a touch? That would help pull the gearing increase on motorway hills.
Post #601174 12th Feb 2017 1:17pm
MJN110
Yes i was planning on adjusting the pump and boost.
Post #601335 12th Feb 2017 8:57pm
MJN110
I was hoping that somebody with a 300tdi with the higher 5th gear option would have responded.
Maybe nobody has opted for it?
Post #603875 22nd Feb 2017 10:49am
miker
I have a TD5 with the higher 5th and very happy with it.
A friend has a 300tdi with a 1.2 Tbox and is very happy with it, thought it is slower off the line.
Based on that, I'd say you'd have no issues with the v8 5th in a 300tdi!
Post #603889 22nd Feb 2017 11:32am
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
I have a 300Tdi with R380 box with 5th gear, Td5 transfer box. Great on motorways but need to be over 35-40 before changing up otherwise it labours. A Slickshift makes gear changing much easier. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #603950 22nd Feb 2017 5:54pm
MJN110
When you say you have a td5 transfer box are they not the same as a 300tdi? Or do you mean you have a 1.2 ratio transfer box like a disco combined with the higher 5th gear option from ashcroft?
Post #604039 22nd Feb 2017 9:35pm
Page 1 of 3 123>
