Home > Technical > Door Hinge
AdamGT3
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Corris Grey
Door Hinge
Hi
I noticed the drivers door becoming tight to close and then noticed this yesterday. I read somewhere about the washers in the door rusting and I guess that is what has happened here, do you think that is right?
If so, what is the recommended fix?
Thanks
Adam
Post #600882 11th Feb 2017 8:09am
Firstly, clean it up and spray if with ACF50 and see if that helps. If not, then replace the hinge. Darren
Post #600889 11th Feb 2017 9:01am
Mo Murphy
A drop of oil ?
50 Shades of Pennine Grey
Post #600898 11th Feb 2017 9:48am
Bluest
I've been getting a rust streak from my hinges. I've been spraying with a thin aerosol grease but so far that just seems to be flushing more rust out. I'm still hopeful it will improve if I do it every time I wash the car. 2007 110 TDCi Station Wagon XS
Post #600904 11th Feb 2017 10:04am
AdamGT3
Thanks all.
Tried cleaning and as for Bluest just flushes more rust out and have then treated with ACF50 with the result in the photo so I guess its new hinge time.
Which is best to go for? I see you can get them for £6 but are britpart ones and need painting!!
Thanks
Post #600906 11th Feb 2017 10:14am
Retroanaconda
Genuine hinges are the only ones worth bothering with in my experience.
Has the door actually dropped? If you are having problems shutting it then I guess so but it would be worth checking as if it hasn't dropped then you may be able to get away with just adjusting the striker. The hinges will show rust for some time before they actually develop play sufficient to affect door alignment/closure.
Post #600944 11th Feb 2017 1:47pm
