Home > Maintenance & Modifications > Fitting a check temp sensor
Page 2 of 4 <1234>
bob neville
Thats normal if you only connect the 12v permanent and earth - you need the switched live to be connected as well.
Connect the permanent live, switched live and light cables to positive and black to negative and it should spring into life.
Bob
Post #60047 19th Feb 2011 5:31pm
kljw
Scotland 2009 Defender 90 Puma 2.4 SVX Soft Top Auto Santorini Black
Bob
chhers for the info, will have alook at that tommorrow. Cheers
keith
puer claudius
Post #60073 19th Feb 2011 7:28pm
MartinK
THANK YOU for posting guys. Thumbs Up
Just ordered mine...btw you can now get them off AMAZON (still through Conrad) here
http://www.amazon.co.uk/10330-Check-Temp-I...amp;sr=8-3
It's a £1 cheaper, but also quicker if you're already an Amazon customer (i.e. all you address details & account already set up). Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #98039 4th Nov 2011 10:43am
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
did not see it mentioned yet but you can wire in the contact relay of the checktemp in series with the AC switch.
Program the checktemp at your desired temp and it will engage the airco automatically while you maintain the possibility to switch off the airco by using the original switch.
For demisting/ winter time, press the right side button for 5 secs and the monitoring function is switched off an your original switch works as normal allowing you to switch on the airco even if the cabin temp is lower than the set checktemp temp.
Dont know if the text makes sense but it works great.
cant remember if i used the NC or NO contact of the checktemp
Smile
Post #99707 13th Nov 2011 4:54pm
pom
if you dont fancy all that hard work you could get a scangauge which uses the landy built in sensor.
Pom
Post #99718 13th Nov 2011 5:43pm
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
cant remember if i used the NC or NO contact of the checktemp Smile
Which wire did you break into at the back of the aircon switch Tatra?
Post #230807 26th Apr 2013 8:15pm
Thud
United Kingdom 2008 Defender 90 Puma 2.4 SW Zermatt Silver
Excellent thread. Going to make this my next project. Thanks.
Post #230849 27th Apr 2013 6:27am
instead of the temperature gauge, why not just plug in an UltraGauge ? it has temperature as well as loads of other engine information and can be used to review and reset any faults. LorryMan100 produced a great write up on the forum and the unit is about £60
it plugs directly into the OBDC socket and the only tricky bit is running the wire around the back of the dash to the window.
Post #230855 27th Apr 2013 6:51am
landybehr
there“s how/where I chose to put the sensor cable. Hard to tell from the pic, but the sensor is rivetted to the wing“s aluminium just underneath the headlamp.
The position seems to make it very little influenced by road-dirt, engine-heat or sun radiation, be the car stationary or on the move. I like that - don“t want to drive some time until the reading settles down to the real values (should I have parked it for a while in the sun).
Post #231039 27th Apr 2013 8:52pm
borderterrier
I have a Garmin eco that does all that, but I like the check temp as its a dedicated item that can be fitted into the dash. I also like the fact that it can manage the aircon.
Post #231060 27th Apr 2013 10:40pm
borderterrier
Anyone done the wiring for this to control the aircon?
Post #232736 4th May 2013 8:40pm
borderterrier
Sorted and it works brilliantly Very Happy
Thanks DG
Post #234998 12th May 2013 7:47pm
dgardel
Italy
Thanks DG
You are welcome!
Scheme 1 or 2? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #235035 12th May 2013 8:55pm
borderterrier
Thanks DG
You are welcome!
Scheme 1 or 2?
1 mate. Not sure what the heating cooling setting does though?
Post #235039 12th May 2013 8:59pm
Can you post up the wiring details for linking into the aircon please
Post #235048 12th May 2013 9:18pm
Page 2 of 4 <1234>
