Home > Maintenance & Modifications > Fitting a check temp sensor
Page 4 of 4 <1234
Furball
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
Thanks Richard. I did find them for £59 outside of Amazon, so wanted to make sure I was getting the best deal.
Post #499039 1st Feb 2016 12:31pm
Jamie W
United Kingdom 2009 Defender 90 Puma 2.4 HT Galway Green
JB sorry for not responding sooner. The link Richard posted seems to be the one. If you follow the instructions previously posted you will have no problems. If you can remove the steering wheel before cutting the hole it will aid access. I used a junior hacksaw blade (minus the handle) to cut the hole as you have better control. Make sure you mask the dash and drill 4 holes in each corner of the aperture then open up with the junior hacksaw blade.
Good luck
Jamie
Post #504155 12th Feb 2016 11:35pm
Page 4 of 4 <1234
