Home > Puma (Tdci) > Help with 2.4tdci smoke |
briggsy Member Since: 26 Aug 2015 Location: Norwich Posts: 5 |
Hey Danny - when you had the injectors checked did you get any information back from the individual tests ie flow test, return amounts etc?
29th Mar 2016 9:41am |
dannyc85 Member Since: 17 Feb 2016 Location: Middlesbrough Posts: 39 |
No mate they just said 1 was faulty and the other 3 weren't far off gone so I got all 4 refurbished.
30th Mar 2016 9:29am |
ah ok - I was also wondering if you had just one refurbed or all 4, I'm presuming they refurbed the set that they took out? Just something to be aware of as the injectors are coded (appologies if this has been mentioned in this thread already) and need re-coding if they are changed.
I had all 4 injectors refurbed as mine was smoking heavily but mine also had a slight misfire on start up - refurbing the injectors has got rid of all my problems with smoking. |
5th Apr 2016 6:24pm |
stobbie Member Since: 04 Dec 2015 Location: zenderen Posts: 17 |
Have you ever found the cause of this?
8th Feb 2017 8:30pm |
