Home > Puma (Tdci) > Help with 2.4tdci smoke
Page 1 of 3 123>
dannyc85
United Kingdom 2007 Defender 90 Puma 2.4 CSW Stornoway Grey
My 2007 2.4 tdci is blowing a massive cloud of smoke when driving off. This only lasts for about half a mile then stops. I have recently had faulty injectors repaired which has stopped some of the smoke but there is still loads there. Iv checked all the hoses and they are all in good condition but there was oil in the hose from between the airbox and the turbo. There was also oil in the intercooler. On a Transit forum someone had a similar issue and said it was the turbo gasket. I replaced the Turbo last year but used the original gaskets as they were in good condition. Anyone able to point me in the right direction? Thanks.
Post #515433 17th Mar 2016 8:08pm
RED-DOT
EGR valve? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #515464 17th Mar 2016 8:53pm
dannyc85
Iv taken the egr valve out and cleaned it also tried to run it with the egr unplugged but hasn't made any difference.
Post #515713 18th Mar 2016 1:55pm
RED-DOT
MAF sensor? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #515716 18th Mar 2016 2:00pm
Eduardo
danny85,
Probably a silly question but what kind of smoke you have? Black, Blue or White?
Smole appears when you accelerate or its all the time?
Cheers Eduardo
Post #515733 18th Mar 2016 3:14pm
dannyc85
Eduardo it's white smoke mate. It happens when I start the engine then disappears after 5 minutes then again for half a mile when first driven. It doesn't matter how long I leave the engine to warm it doesnt make a difference. It's a really massive cloud of smoke as well
Post #515754 18th Mar 2016 4:31pm
dannyc85
MAF sensor has been cleaned with contacter cleaner. There are no fault codes showing?
Post #515755 18th Mar 2016 4:32pm
dannyc85
Sorry smokes a lot worse whilst accelerating
Post #515756 18th Mar 2016 4:33pm
Stacey007
Has it been re mapped or tuned?
Post #515762 18th Mar 2016 4:59pm
dannyc85
No just standard.
Post #515785 18th Mar 2016 6:02pm
dorsetsmith
is lube oil level in sump increasing ?
next quenton the smoke color white ?
smoke smell of diesel ?
Post #515790 18th Mar 2016 6:13pm
dannyc85
The oil level in the sump is fine it's never changed. The hose from in between the turbo and air filter to the engine is wet with oil same as the intercooler. Not loads of oil just a wet coating I was just wondering if faulty turbo gaskets could cause this. Yes mate white smoke and it smells
Post #515803 18th Mar 2016 6:44pm
Eduardo
Depending of the ambient temperature a faulty glow plugs can cause white smoke, diesel odor during engine cold start, maybe can be that
Cheers Eduardo
Post #515804 18th Mar 2016 6:50pm
dannyc85
Yes that could cause the smoke on start up but would glow plugs still cause smoke when driven even if the engine is warm?
Post #515808 18th Mar 2016 7:20pm
jst
white smoke on a cold start up is normal in the colder days of late on them.
You starting it and driving off straight away? or leaving it 5mins then driving off and getting the smoke? (after initial start up)
coolant is all good?
whats mpg like? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #515828 18th Mar 2016 8:29pm
Page 1 of 3 123>
